Question about Dryers
DRYER STOP SPINNING , DRUM WILL NOT MOVE - Dryers
    President:
  • 1,136 Answers
Hi, I can help you. Please get me the model # so I can give you instruction on replacing the belt.
Vic
Posted on Jul 02, 2009
How do I stop my dryer from spinning?
Could be bad timer but check the timer knob first have seen them crack so they are not pointing in the right direction
Dec 09, 2015 | Dryers
Drum keeps spinning after dryer door is opened
What is the model number of the unit?
Nov 03, 2012 | Kenmore Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
My dryer flew off of a dolly when loading it on a trailer to move it. It smells like rubber is burning when I turn the dryer on. It was working fine until we moved the dryer. Could it be the belt is loose?
If the dryer fell some distance, the drum is probably out of alignment.
If the drum is not spinning at all, something has jammed the drum and the belt is being overheated by the motor pulley.
If the drum is spinning and there is a rubber smell, the drum has been knocked off of its rollers and/or glides.
In either case, the dryer needs to be opened. Click the link below:
http://www.applianceaid.com/may-apart.html
There are two basic types of Maytag dryers, older models and the newer ones with the door that wraps over the top ('L' shaped door).
Apr 07, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Dryers Logo
265 people viewed this question
Top Dryers Experts
Marvin
Marvin
