Open cover message
SOURCE: Dell 922 "cover open" problem / error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
SOURCE: Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
SOURCE: Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
SOURCE: Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
