Question about 2wire 2700HG-B Router (2700HGB)
2WIRE 2701HG-B gateway modem doesn't connect to internet. Called ATT tech support and all they can say is they don't see connectivity problem from house to their location. DSL led keeps blinking. Tried to restart many times but still same problem exist.
  • MacMan23 May 11, 2010
    Please Be a little bit more clearer on what this means. What are the status lights doing on the modem, that could tell us what problem you are having, also are you running with a ethernet cable or wireless.
    Check to see if all phones are filtered,
    Phone cable damaged,
    Phone cable can not be longer than 10 feet MAX!!!!!!! and if you do need to keep the modem near the phone wall jack, get a ethernet cable that will be-able to reach your computer, Ethernet cables can go 100+ feet.
    Do you have static on your phone line, if you do, call AT&T and report static on the line.
  • 70 Answers
Unfiltered phone jack or internal wiring problem
Posted on Jun 19, 2010
2701HG-B ATT modem/router won't answer ping 192.168.1.254
what is the default gateway for the ip address of whatever computer you are using ?
Not sure if they can change it but looking up the default gateway ip address will give you the router ip address if DHCP is being used and if it has changed somehow ?
Jun 06, 2017 | 2wire (2701HG-B) Wireless Router
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Att2wire 2701hg-b to replace peoplepc dsl Zyxelp-600 series modem
do you also have AT&T? att2wire 2701hg-b gateway is configured to work with AT&T only that's why if you have a different ISP, it will not work for you. Most ISPs provide modems that are configured solely for their service.
Apr 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
2wire 2700HG-B Router (2700HGB) Logo
1,627 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
