Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi CS30 Spool Retainer wont come off!
I can't unscrew the Spool Retainer off! I've only used the trimmer 2 or 3 times. The manual says to screw it CLOCKWISE to take it off, and i've tried that (to the point of throwing things). I've also tried counter-clockwise, just in case. The thing is stuck. Is there some trick?
  • thedevine1 Jul 03, 2009
    Figured it out. Well, actually, my hammer figured it out. Yes, I resorted to beating the big black "screw" with my Estwing. One good knock and the thing spun right off.
    The reason I was taking it off was because there was no more line out of the holes. I assumed it had all been extended....but no. One of the lines was stuck underneath itself (like, when you wind a hose and it overlaps itself, making it stick and not come out). The other side had "melded" itself to the spool. I guess it got hot and melted to the plastic of the spool. I was able to get both sides loose, but i didn't have enough line to trim anything. All that work for nothing.
  • 110 Answers
No trick - sounds like it is stuck!
Can you take it back?
If no - well - keep trying :(
Are you taking if off to put on other head attachment?
Posted on Jul 02, 2009
  • mattofilms
    mattofilms Jul 03, 2009
    Now you have got it of - check out a alternative head for your machine.
    like this:
    http://trimmerhead.com.au/
    I know you can get one like this from Bunnings.
    Much easyer to change string - and works much better!
Where can I get a spool retainer for my ryobi 24 volt string trimmer
Fixya is unable to suggest Ryobi spool retainer sources.
Apr 12, 2018 | Ryobi Garden
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Trimmer head line loading instruction
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
Ryobi CS30 straight shaft. I can not get the string head off to replace the line.
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi cs30 wont start
what do you do when there is no spark??????????????????
how do you fix???????????
Mar 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Jammed line spool on Ryobi gas trimmer
I have a microwave that arch for no reason after it has been running more than 1 minute. if I'm warming a cup of coffee it arch. if I'm popping corn it archs. Could the bulb inside of it be bado or going bad? How do I replace the bulb? if you can't help me, could you forward this to someone who can. I bought the microwave from Seaars 2-years ago.
Jul 17, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
3,362 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
