Question about Apex Digital LD1919 19 in. LCD TV
How do I access the circuit board on the Apex LD1919?
Apex LD1919 blinking green power light. Removed all screws from rear of tv, but I cannot get the two halves separated. This is to possibly replace the (2) blue capacitors.
How do I remove the two halves of the tv to access the circuit board?
All the components are screwed to the back of the cabinet. Once the back screws are removed, the front bezel snaps off. (Not easily, but take courage and try.) Release a connector in a set of leads to the pilot light panel to get enough slack to lay the bezel flat. The LCD panel then removes with seven silver screws (one is a ground lead). Move it to the side, and the power supply board is accessible. Two connectors and four screws, and it comes out.
Posted on Jul 13, 2009
Apex ld1919 power light just blinks instead of going on
Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting itself back to the tv factory setting.The tv now should be working again.If the tv dosen't and the tv still having the same problems.Mean ur tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 28, 2011 | Apex Digital LD1919 19 in. LCD TV
Tv will not turn on and green light blinks 3 times constantly
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Jul 14, 2011 | Toshiba Regza 52XV645U LCD TV
Tv green light is plinking. But tv won't come on, it acts like its.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 20, 2010 | Apex Digital LD1919 19 in. LCD TV
T.v green light blink t.v wont come on
Power board is dead.Need it replaced.Tries Shopjimmy.com,Ebay.com for part.
Jan 22, 2010 | Apex Digital LD1919 19 in. LCD TV
GREEN LIGHT COMES ON BUT TV WONT LIGHT UP AND WONT TURN OFF
Call the number on your TV manule and tell them you probley have a Loos Fuse in your Tv
Jan 05, 2010 | Apex Digital LD1919 19 in. LCD TV
Blinking green light and won't turn on
bad capacitors on the power board just one bad on mine! posabilty of 3 two are 1000uf 25v and and the other is like 400v 100uf or something. I pulled one out of an old satalite reciever good luck Thanks JT
Oct 19, 2009 | Apex Digital LD1919 19 in. LCD TV
Apex 19" #LD1919
1. UNPLUG the TV from the wall or power strip.
2. Turn ON the TV (w/o the power plugged in).
3. Plug the power cable back in.
4. Turn ON TV ... it should work...
5. Also... adjust antenna if you are on "broadcast" mode.
Sep 03, 2009 | Apex Digital LD1919 19 in. LCD TV
Green flashing light on but tv won't turn on
Check capacitors on the power board. Two 1000 uF 25V and one 150uF 400V.
Jul 15, 2009 | Apex Digital LD1919 19 in. LCD TV
Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
May 17, 2009 | Apex Digital LD1919 19 in. LCD TV
Tv will not turn on
Common problem with this set are the two 1000uF@25v capacitors and the 150uF@400v cap on the power supply board.
May 12, 2009 | Apex Digital LD1919 19 in. LCD TV
Apex Digital LD1919 19 in. LCD TV Logo
679 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
