Question about Asko TL751 Electric Dryer
Asko dryer: room temp air, is not heating
Our Asko dryer is tumbling but the air is only room temp: heating element? anything else?
  • 407 Answers
I would first make sure the dryer vent is cleaned out really good, from inside the dryer all the way out of the house, and make sure it isn't blocked anywhere. Thats usually what causes this type of problem. If not, then yes, it will be an electrical problem. Hope this helps.
Posted on Dec 28, 2009
  • 725 Answers
First try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
How does the air dry cycle work?
Are you asking about the fluff or no heat cycle?? It just blows room temp air through your clothes. It would be similar to hanging them outside but with the drum tumbling them. This will of course take much longer to dry than with heat.
May 10, 2015 | Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
GOD IS still GOOD !!!!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Sep 16, 2014 | Asko Dryers
My ASKO T781 butterfly dryer is heating up but not tumbling/spinning
If yourdryer is not starting then it is your motor. To determine this there is a trick you can try. First, put a piece a tape over the safetyswitch on the dryer. Take one hand andspin your drum of your dryer as your press the start button. If it takes off, then there is a bad spot onthe motor. Another thing is to try checkto see if you are getting 220 Volts to you outlet by taking a volt meter set at250 volts. Take the red leg of the volt meterto the one side and the black leg to the other side. If the volt reader reads 220 then you aregetting the proper voltage. Finally, ifyou are getting 220 volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is forthe motor and leg is for the element. Ifyou are getting 220 volts then it is more than likely you have bad motor.
May 15, 2011 | Asko Dryers
Element in the back seems to be heating but not spinning around. Cleaned filter.
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Asko T712 Electric Dryer
Kenmore 100.72822101 gas dryer. Will not dry clothes completely. I disassemblyed and cleaned the entire vent system on the back. Now have a lot of air flow out the exhaust. Checked the air temp of air...
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Kenmore 72872 Gas Dryer
ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Dec 05, 2009 | Asko T731 Electric Dryer
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
Does not heat, air blows, drum tumbles.
then DIY we do not read minds as to MAKE
Sep 28, 2017 | Dryers
Asko TL751 Electric Dryer Logo
242 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
