I have managed to manually open the door on my hotpoint wmud942 ultima washing machine but the key symbol comes back on as soon as I close the door, I have some more problems the washer will run a program but no water seems to come into the machine, I have checked the filter at the front and that's ok. Please could someone help. This all started when my builder moved the drain hose and f05 fault code kept coming on.
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
If there is water left in machine door stays locked but if you remove the plug after about 3 mins the door may open be careful if there is water in it when you open the door
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal. Don't forget to look in the manual for how to get the door open in an emergency
you will need to remove the top cover and get a screwdriver to move the door latch over. it's a job for an engineer really as you have an electrical problem anyway.
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
