Tv will NOT recognize dvd player. My manual has been lost. I need to know the which buttons to push in which sequence to show dvd movies on the tv. remote model BP5-00124A
SOURCE: Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Posted on Jan 11, 2008
  • 7 Answers
SOURCE: lost remote
Fairly easy and resourceful fix for this. Spent the past hour on the net looking, and no one had any info. So, we post here!
Our remote was lost, and were in the same unable to use the input port situation on our Durabrand BH1304D. Tried 3 universal remotes with no luck. However--- we are back in business now, Houston!
My fix-- grab a DirectTV remote (we had a white one-- RC 32 is the model). It's compatible with this 13" Durabrand TV, and most people a neighbor probably have one!
To program it to the TV (at least in our case), you have to slide the top switch to TV, then hold and press MUTE and SELECT until the green light flashes twice under the TV switch. Then press numbers 11034 and the light should flash twice again. Ta-da! Should be in business. We were!
The input button also worked as is, no need for the other step listed in the remote manual. But if your TV is changing channels and volume, but no input button, quick easy fix there too apparently. Didn't have to use it, but the input button can be activated or deactivated as needed. Simply hld SELECT and MUTE down again, the hit 960 on the keypad. That should be the activate/deactivate code per the manual.
Hope this helps someone, as the durabrand remote situation stinks, but thanks to the power of internet and users like us, there's now a solution in your reach! :)
Steve
karaokestl.com
Posted on Feb 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: no remote control
Try replacementremotes.com
Posted on May 17, 2008
  • 20 Answers
SOURCE: lg remote
Assuming you have not shot your in-laws and are now reading this from a jail cell, if you hold down 'TV POWER' and press number '8' or '9' on the remote, you should get it working again. I've just got a new Sharp bells'n'whistles TV, and the remote doesn't work fot it at all. Bummer!!!
Posted on Jul 16, 2008
Electro-tech
  • 22 Answers
SOURCE: I've lost my manual for my RCA 27" tv model f26634sf I need to program the remote
Try, Service Manuals.net
Posted on Aug 27, 2008
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
DVD 6655, audio plays, but no video showing, nothing shows, when pushing menu, program, cords all plugged in, DVD clean, tv correct setting, cords good, only played one movie since new
Hi tappetanders,
There are usually two AV modes in the TV which allow you to select the source , therefore , you need to select the correct one, usually there is a button names as AV or similar which allows you to select the video input source, once you select this source properly then you should be able to see the video.
Hope this helps ...:) Let me know in case you have any further queries.
Aug 29, 2011 | Curtis Televison & Video
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
Remote control for Cyberhome CH-DVD 300 is lost.
they are stop, eject, play ,ff, rr, pause, and power.
Jul 15, 2010 | Cyberhome CH-DVD 300 DVD Player
Lost remote - can't navigate between episodes on DVD
You do need the original remote however, you can use your TV remote or your cable/SAT remote. They usually have DVD button on them. You just need to read the manual on how to program these remotes to worl with your DVD player. If all else fails, Radio Shack or CVS has universal remotes for about $10 ~ $20.
Mar 23, 2009 | Panasonic Televison & Video
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
Swiching from tv to playing video
sorry. you cannot switch to video mode without the remotes
Feb 21, 2008 | Disney Princess MCP DVD2050P DVD Player
No picture on Television
You have provided incomplete information. What do you mean by 'dvd player works'? Do you mean you are able to view the DVD movies on the TV? Or does it mean that there is power and various lights and indicators on the DVD player?If you are unable to see picture - both while viewing DVDs and also Broadcast channels, then there is a major problem with the TV.Get a professional to have a look, then. But if you are able to view DVD movies, but unable to view broadcast channels, then it is a simple problem of input selection. In this case just select the TV/Video or TV/AV button on your remote, if there is such a button. If no, then use the menu and scroll for input, and then select Tuner. First clearly state what your problem is. Only then we can give you better advice.
Aug 23, 2006 | Jensen JHT-350 System
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
