Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Leaking from the door
We have a leak from the door of our Maytag dishwasher. Everything looks intact so I don't know what would have changed to start the leak. A lot of water is in the basin, could the drain be plugged?
  • Anonymous Dec 26, 2007
    We too have a leak from the front of our Maytag dishwasher. We checked the plumbing fittings and they appear to be fine. We believe the gasket is the problem based upon the source of the dripping water.
This has happened to us a few times. There is a gasket inside the door for a solenoid that operates the flap that opens to let dishwasher detergent out. The gasket went bad and water leaked through.
The only thing to do is replace the gasket. It's a $8 part. (A lot for a 1 inch square gasket!) They seem to last about 2-3 years.
Posted on Nov 18, 2007
On my Kenmore Dishwasher Model 66513749K601, the door is leaking water. I'm wondering if changing the gasket will repair it or if this machine has a history of other issues.
Hi, Just change the door seal... it is very easy to do...and don't cost much at all...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Maytag jetqueen door leak
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Brown liquid leaking from bottom of door on right side minutes after dishwasher starts.
water is getting inside door and sound deadening material is washing out..remove door panel and locate the source of the leak(look around the dispenser)
Jun 13, 2009 | Maytag MDB7100AWB Dishwasher
Hi there. Have you started using new tablets. Ours does the same thing if we use certain tablets. Ours is too much soap suds coming over the bottom tray, so If you have filled up all your other fluids and then use a 3-1 tablet it may be producing too much suds. These then overflow out of the door and drip out at the bottom of the door.
Hope this helps! It seems weird I know!
Don
Feb 15, 2009 | Maytag Dishwashers
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
175 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
