Question about LG LRBN20510WW Bottom Freezer Refrigerator
Ice build up in the bottom of the freezer
Every couple of weeks I have to chizel an inch of ice off the bottom of my freezer because of this problem...I am going to check out the drain hose.
    President:
  • 1,136 Answers
Hi, Remove the rear panel inside the freezer and locate the drain ole. Remove all the ice and flush the drain with hot water. Try pushing a soft wire through the drain to make sure it is clear. A baisting seringe to blow water though the drain.
I hope this helps you. please let me kow if I can assist you further.
Vic
Posted on Jul 02, 2009
  • 4,070 Answers
Your don't ask a question but you're headed in the right direction. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Ice build up every few weeks
Change the defrost heater inside the freezer. Located behind panel inside the freezer at the bottom.
Jul 09, 2009 | Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Makes a lot of ice on bottom of freezer floor, water all over the floor every day, iced up 3-4 inches needs defrosting ever 2 weeks
drain is blocked - usually with ice and possible you have a fault with the defrost system.
take back cover off inside freezer and you will find ice build up at the bottom. melt off carefully with a hairdryer and follow up with hot water flows away freely.
if the whole of the pipework is blocked with ice, you have a fault with the defrost system so get back to me
Aug 13, 2008 | Maytag Refrigerators
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
LG LRBN20510WW Bottom Freezer Refrigerator Logo
398 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
