Question about Trendware TRENDnet TEW-431BRP Wireless Router
My tew431brp status led is permanently red, it won´t work, it´s not possible to go to the config menu again, the old configuration previously stored doesn´t work either
    Scholar:
  • 111 Answers
When in doubt flash it! Though you must reset it to default protocols first. There should be a reset button somewhere on the unit, press and hold for at least 15-30 sec. If this does'nt work you may have been zapped by some stray volts and in this instance is not cheaper to keep her.
Posted on Jul 02, 2009
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Tip
How to print a config page on a Ricoh printer
On Ricoh printers, the configuration page (also called the Config page) is an information page that can be printed out with detailed data about the machine's status. The Config page shows the printer's copy count, various network settings, and current firmware versions, among other things. One nice feature of the Config page (on most printer models) is that it shows how much toner is left in the cartridge or bottle, so you can find out if you'll need to order more soon.
Follow the steps below to print a Config page from a stand-alone Ricoh printer.
A. Turn the printer on and wait for it to warm up.
B. Press the Menu button.
C. Scroll through the list of submenus using the up and down arrow keys until you see List/Test Print, then hit the OK button.
D. Look for the Config Page option, and hit OK again.
The configuration page will print out, and depending on that specific printer, it might be two pages rather than one. Whether the printer is black and white or color, the configuration page will be printed in black and white. If you want to print a test page in color, scroll further down the List/Test Print menu and you should see something called the Color Demo page.
To print a Config page from a multifunction Ricoh printer (one that scans and copies as well as prints), the steps are similar, but some of the machine's buttons are different. Multifunction printers typically don't have the Menu button, so you would press User Tools instead and then go to Printer Features. From there, the process is pretty much the same as described above.
on Jun 19, 2010 | Office Equipment & Supplies
Tip
HP LaserJet 4250n: How to print a config page
Almost all modern printers have the ability to print out a configuration page -- a pre-formatted page with all sorts of information about the printer and its status. The items found on a config page will vary from printer to printer, but typically they include the network address and other network settings, a list of optional features that have been installed, the printer's page count (number of pages printed), and possibly the current ink levels. For color printers, the page count is typically broken up into black and white (or monochrome) and color.
To print a config page on an HP LaserJet 4250n, follow these steps:
A. If the printer is not already powered on and warmed up, turn it on now. Then hit the Menu button (the gray button to the left of the display screen.)
B. Using the down arrow button, scroll down once to Information and hit the Select button (the green button with the check mark on it).
C. Hit the down arrow button again to scroll down to Print Configuration and hit the Select button again.
The config page -- which might actually be two pages if you have a JetDirect print server -- will print out immediately if the machine was at the Ready screen when you started, or it will print out as soon as the printer warms up if you just turned it on. The display screen will automatically return to Ready.
If the printer is currently in an alert state -- because of a paper jam, empty ink cartridge, lack of paper, or other problem -- it won't be able to print the configuration page. Remedy the problem shown on the display screen and try again.
on Jun 17, 2010 | HP LaserJet 4250n Printer
Cisco 3750 web config
Yes, know more about the Cisco 3750, just visit: http://www.3anetwork.com/cisco-catalyst-3750-switches-price_c41
Dec 26, 2013 | Computers & Internet
I have a pair of Comtrend 8902 which have been working well for a couple of years. However, as of last Saturday, the AP LEDs are all flashing red. Holding down the standby button does stop the flashing,...
I don't have those particular ones, but I have added more units to an existing pair of powerline adaptors. They are not paired, but simply configured onto the network you have set up. Once you have the initial pair set up it should be possible to add as many others individually as you need.
hope ths helps...
May 16, 2011 | Computers & Internet
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
Change sys config emulation oki b4250
You don't need the Status Monitor to do this. Just change the loaded Driver under Properties.
Feb 04, 2010 | OKI B4250 Led Printer
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Tray Error, Invalid Config
You can restore the original factory default menu settings by initializing NVRAM. Try this and see what happens. from there I would need an exact message off the printer to help further.
Turn off the printer.
Turn on the printer while holding down u_botton.gif and d_botton.gif .
The Customer Mode menu appears.
Press Menu.
Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
Turn off the printer, and then on again.
Oct 19, 2007 | Dell 3100cn Laser Printer
Activity Reports
First of all, Back up your configuration by printing it.
[Menu] --> [Reports/Lists] --> [User Data List]
then go back to main menu
[Menu] --> [#] , it will display #SSSW
Use the [+] [-] buttons till you see [#CLEAR]
Press [OK]
That resets all the configs and status flags.
With the initial config in hand, you are ready to setup you device and we all live happily ever after.
Try it out, it works perfectly and on most models
Aug 28, 2007 | Canon LaserBase MF5650 All-In-One Printer
Trendware TRENDnet TEW-431BRP Wireless Router Logo
291 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
