Canon PIXMA  MP160 All-In-One InkJet Printer
Problem for Canon PIXMA MP160 All-In-One InkJet Printer
Error number 3
By z123 on Nov 09, 2007
i've take out the paper, but still cannot solve the problem
Clarification Request
Posted by mdmorel on Sep 19, 2009
Thanks for the card stock solution. I used one of those junk mail advertising postcards about 5 in x 9 in. Shoving it through sent a coin out with it. A few more times with paper and I was now 36 cents richer (three dimes, a nickel, and a penny were all in there). Yes, this printer is in a busy area frequented by children!
Works fine once again!
Posted by pasina on May 18, 2009
Solution link . . . http://www.CanonPIXMAMP160InkJetPrinter.com,
Same Problem
Dec 26, 2008
-   I had 4 of these beasts. They are used every other day quite a bit. I had the "phantom paper jam". I took the advise of the smart folks out there and did the paper force game. I forced a piece of card stock through 5 times. Nothing. BUT then it got half stuck and i pulled it back out. Abracadaba fixed. It could have been due to the huge paper clip that came out with card stock that time. So check you printer of other office supplies that don't belong. :) Thanks to all.-   Guest
Nov 22, 2008
-   i have an erroe with my printer Canon Pixma MP160 service error 5100-   raj09
Nov 21, 2008
-   I have the printer error of E3, but there is no paper jam. The yellow alarm light is on.-   kcreer
Nov 11, 2008
-   Paper not accept & Eror 3 to display-   Guest
Oct 05, 2008
-   as soon as i turn on my printer it says error 3.nothingt else works.i don't know what is wrong.the yellow alarm light is on too.open to all sugestions.-   Guest
Best Solution
posted on Mar 21, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My Canon Pixma blinked E3 for days being non-usable. But I tried it and it worked. I cut the back cover off a high end home design magazine. I turned the printer off. Then on... as it rebooted I force stuck the magazine cover into the paper feed. First time nothing changed. I did it again and the printer booted up with a 1 instead of a blinking E3. Thanks By Owner
Maybe there are sensors or switches that had to be reset near the paper rollers. Who knows. And the problem started after changing the black ink cartridge.
Solution #2
posted on Mar 20, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
worked for me :)
Solution #3
posted on Mar 05, 2008
Helpful)
garty
Rank: Master
Rating: 89%, 130 votes
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Jan 20, 2009
Very Helpful)
angepange
Rank: Apprentice
Rating: 100%, 4 votes
Make sure you power the printer off. While powered of, disconnect the USB and Power cable from the rear of the printer. Re-attach the power and USB cables. Power the printer on. Normal booting of the printer should take place and it should boot showing a single page is selected to print. Now use a piece of card stock or poster-board cut to 8.5" X 11" and print a test page. The card stock will begin to be pulled through the printer. It may stop. due to a "True" printer jam. Easily pull the card stock from the printer as if it were printing. This should remove any paper jam. You may have to do this more than once. Try this eay method before throwing the printer away as I was about to do. happy printing
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on May 18, 2009
Helpful)
tortole
Rank: Master
Rating: 81%, 9 votes
Try this link . . .http://www.Canon.com/PIXMAMP160All-In-OneInkJetPrinter
For find best solution.
17
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #6
posted on Mar 16, 2009
Helpful)
ksdi
Rank: Wiz
Rating: 82%, 28 votes
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
268
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Dec 20, 2008
Helpful)
jimejo
Rank: Apprentice
Rating: 88%, 2 votes
This MP160 swalled a paper towel. Cleaned it all out. Still have the problem. Alarm lite is on and printer lite flashes from captial E to captial 3
Was this helpful?
Yes
No
Solution #8
posted on Dec 17, 2009
Not Rated)
jeegee
Rank: Apprentice
Rating: 0%, 0 votes
worked for me! I forced a birthday card into it when i connected power cable (to make rollers start), then tried the feed 3 sheets option, a tiny bit of paper came out and voila 2 run throughs later its as good as new
Was this helpful?
Yes
No
Solution #9
posted on Oct 04, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I used the shove a piece a paper through it solution and it worked a treat.
Thanks for that tip - as it was pretty close to chucking the printer out of the window time!
Popular Solutions for Canon PIXMA MP160 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP160 All-In-One
Do you recommend Canon PIXMA MP160 All-In-One InkJet Printer?
Answer
Answer
MP160. Will not print. Error message, remove paper jam and push start button. there is no jam and... (More)
Answer
When I turn the power on to my cannon MP160 only the alarm light comes on (not Blinking) and nothing... (More)
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 16, 2008
yep same problem-error 3 - no paper in there!
unplugged it, shook it, nothing..........
Comment by Piasa, posted on Dec 03, 2007
printer make an odd noise and tells me error 3
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , IL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
