Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
I HAVE A JET3 ULTRA. WHEN I TURN IT ON, THE CHARGE LIGHTS FLASH BUT THAT IS ALL. THERE ARE 8 LIGHTS FLASHING. I UNDERSTAND THIS A CODE. CAN YOU TELL ME WHAT IT MEANS? HAVE NEVER HAD ANY TROUBLE EXCEPT THE TOUCH PAD ON CONTROLLER CAME LOOSE AND THE BUTTONS ARE LOOSE.
  • 1 more comment
  • donald hall Jul 02, 2009
    I will work with firesnake09 but I am handicapped and will have to wait for someone to check it for me.
    Thank you
  • donald hall Jul 08, 2009
    The 50 amp fuse is a circuit breaker. It had not popped so I assume it is okay. There are eight lights flashing. This is a code.
    Donald Hall
  • donald hall Jul 15, 2009
    firesnake; 50 amp fuse is a circuit beaker. It has not popped out. Any other ideas?
    Donald Hall
  • 1,000 Answers
The 8 light flashes indicate and control system problem. Recommendation is to check wiring and connections at the joy stick and power module. The wiring diagram and fault code description are below.
Good luck,let me know.
Best Regards,
Posted on Jul 16, 2009
    President:
  • 2,777 Answers
That is a diagnostic code that simple indicates a problem, most likely the problem is in the joystick area. Unfortunately most places will tell you that you need to replace the joystick assembly, which may be the case. However, has the controller been exposed to any moisture? If so, you may have some moisture in the joystick, causing its connections to the rest of the circuit to go goofy and all the lights to flash very fast (almost flicker). If you take off the controller cover to get down to the bottom side of the joystick use some air from a vacuum cleaner, one of those spray cans used to clean out a computer keyboard or a hair drier on the cool setting to thoroughly dry out the inside of the joystick very well and reassemble. I know someone who saved themselves a couple of large repair bills by doing this after actually paying for the repairs the first time. The little rubber cover over the joystick does not seal very well. You can use some thick dielectric grease to seal it a little better when you reassemble it.
More likely than not this is your exact issue, if it does not fix your issue, or if you are uncomfortable attempting these repairs I would call Pride Mobility at 1-800-800-8586 for either help over the phone or information on a local person who can assess the situation. By the way this unit has a full 5 year warranty on some parts, and 1 year warranty on most of the rest. Maybe it's still under warranty... I know the actual joystick assembly can be quite expensive if it needs replacement.
Hope this helps!
Posted on Jul 08, 2009
  • 365 Answers
I think the customer support can help you better than anyone, the addresses are below.anyway i think this may be due to a charging problem(the battery may be out of charge),try to recharge the system once more.i will post further details later.thank you
The Americas
  • Corporate Headquarters USA
    182 Susquehanna Avenue
    Exeter, PA 18643
    Telephone: 1-800-800-8586
  • Canada
    Pride Mobility Products Company
    380 Vansickle Road
    St. Catharines, Ontario LZR 6P7
    Telephone: 888-570-1113
    Fax: 905-682-7256
    Managing Director: Mr. Brian Fisher
Asia Pacific
  • Australia
    Pride Mobility Products Australia Pty. Ltd.
    21 Healey Road
    Dandenong, Victoria 3175
    Telephone: 61 3 9706-4611
    Fax: 61 3 9706-4622
    Managing Director: Mr. Warren Tripp
  • New Zealand
    Pride Mobility Products New Zealand Ltd.
    38 Lansford Crescent
    Avondale
    Auckland NZ 1007
    Telephone: 64 9 828 0337
    Fax: 64 9 828 0339
    Contact: Dai Lowry 64 275 828 033
Europe
  • Europe
    Pride Mobility Products Europe BV
    Castricummer Werf 26
    1901 RW Castricum
    Netherlands
    Telephone: +31(0) 251-377 577
    Fax: +31(0) 251-377 580
    General Manager: Mr. James Ormel
  • Italy
    Pride Mobility Products Italia S.r.l.
    Via del Progresso, ang. Via del Lavoro
    (Prato della Corte)
    00065 Fiano Romano (RM)
    Italy
    Telephone: +39 (0765) 451143
    Fax: +39 (0765) 455251
    General Manager: Mrs. Federica Pozzi
  • United Kingdom
    Pride Mobility Products Ltd.
    32 Wedgwood Road
    Bicester, Oxfordshire OX26 4UL
    Telephone: 44 1869 324 600
    Fax: 44 1869 323 070
    Vice President International Sales: Paul Rising
    Managing Director: Nick Allen
Posted on Jul 03, 2009
    President:
  • 2,923 Answers
Sounds like that battery is not charging. You may need to check the fuse. You can find the 50 amp Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
Hope this helps and have a great day!
Posted on Jul 02, 2009
How to tell if it is charging
The Jet3 Ultra has an amp meter built in. Remove the rubber cover on the right side behind the wheel and see if the needle is moving.
Feb 16, 2013 | Jet 3 Ultra Power Chair
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
On my Ultra Jet 3 th power lights keep flashing?
Count the number of flashes IE 3 flashes a pause then 3 flashes this is a error code and tells the tech what the problem is. Without knowing the number of flashes I cannot help. If you have your owners manual there should be a page for error codes somewhere near the joystick page
Aug 16, 2010 | Jet 3 Ultra Power Chair
The lights are flashing and i cant get the chair to move. What should I do?
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
May 20, 2010 | Jet 3 Ultra Power Chair
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
'99 Mercury Cougar - Seatbelt light flashes 8 times in pattern
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
Apr 28, 2009 | 1999 Mercury Cougar
Jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Apr 09, 2009 | Jet 3 Ultra Power Chair
8 lights flash when i power up my jazzy1103 ultra
http://www.spinlife.com/Pride-Jazzy-1103-Ultra-Indoor-Power-Wheelchair/spec.cfm?productID=72348 I don't know if this is your wheelchair or not, but this website does have a manual on it, and I did take a look I couldn't find anything about the codes your talking about, I would call the company from which you got it from..and ask them what does the codes mean, or if your not happy, call another wheelchair provider I go thru Hudson Medical calling another company and see if they might be able to help you.
I don't know if this will help but I certain hope it will.
Feb 25, 2009 | Jet 3 Ultra Power Chair
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
678 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
