Question about Samsung SPH-M300 Cellular Phone
My screen won't shut down completely and stays partially lit, the phone works fine otherwise but this shortens the battery life any suggestions how to reset it? it was washed and i have had the problem since
  • 389 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can try to reset the phone by going to Menu, Select Settings , Select Security, Enter the user lock code, using the keypad (last 4 digits of phone number, then chose for reset phone. If this would not resolve your issue it means that it needs repair since the mother board is already damaged.
Posted on Jul 02, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Atwood motorhome furnace won't stay lit
I would say this is your electronic ignition system but it sounds like it is not getting gas. This is why they do a 3 time try and shut off. Check you supply line right down to the regulator. Hose could have got partially kinked along the line as well.
Jan 31, 2013 | Heating & Cooling
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My HTC HD7 keeps shutting down (rebooting). If I talk on the phone for over 5 minutes or send too many texts. I won't send emails or anything else anymore - it just shuts down. It will continua
yes,back it all up onto you sd card in the phone or computer,do a full factory reset and only install the apps you NEED,it should be fine then ,if not i suggest its a battery issue
Jun 27, 2017 | HTC HD7 Cell Phone
Phone won't shut off. Display stays lit all the
The software got stuck whil shutting down. Try resetting it to factory defaults after saving your phone book and other valuable info on there.
Jun 26, 2011 | Samsung Cell Phones
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
Battery will not hold a charge
Sadly phone batteries don't have the long life they used too. There isn't a lot you can do besides purchase a new battery. Samsung only covers the battery for one year from date of purchase, so you might be able to get a replacement if you have had it for less than a year. Otherwise, eBay is your friend. You can extend the life of the battery by changing some habits of how you use the device.
- Let the battery run completely down about (dead phone) about once a month. This helps ensure a longer life.
- Try to avoid using car chargers. The power provided isn't always the most stable and can greatly shorten the life of your battery.
Once you get a new battery, don't charge it right away. Let it run down the first time to empty before first time charge. That will ensure a long, healthy battery life.
Mar 01, 2011 | Samsung Memoir SGH-T929 Cell Phone
Battery life reduced 80%
hi,the problem could be with the battery,change the battery.
hope this is helpfull
Sep 30, 2008 | Nokia 1100
Samsung SPH-M300 Cellular Phone Logo
148 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
