Question about Zenith E44W48LCD 44" Rear Projection HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
I have a 5 month old zenith e44w48lcd, prior to not turning on at all the set would make a humming noise for 4-5secounds and then turn on.. When the set went down, I was in the middle of watching a movie. The set just powered off and hasn't turned on since.. Now when I try to turn it on I get a red light on the operation indicator, and the lamp indicator starts to flash red after a few minutes.. The set dosn't make any noises.. I performed a continuity test on the bulb and did not have continuity, I'm not sure if these lamps are similar to a regular bulb, should I get continuity? And does this sound like a bulb problem?
  • 3 Answers
Re: Won't turn on.. Operation indicator is red, Lamp...
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Posted on Dec 16, 2007
0 characters
3 Points
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Zenuth buzzing sound and no picture tv stuck in stand by
Ck power supply board for Bad capacitors if you see any that are swollen on top they are Bad For caps Call Mats 1-800-628-1118 For Other Parts and Boards Call Encompass Parts Distr or visit their website they List Free service Manual you can download it there 1-800-638-3328 CK Ballast Board it connects to your Lamp it is what turns Lamp on.
Dec 15, 2009 | Zenith Z52SZ80 TV
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Zenith e44w48lcd Won't turn on
need manuals for model z32Lc2d ser719192169807
Jan 05, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
ZENITH E44W48LCD Ballast
Could be a bad ballast or light light control circuit. I have also seen a burned or bad socket cause a problem with this set. Good Luck
Jun 18, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith E44W48LCD 44" Rear Projection HDTV Logo
357 people viewed this question
Top Zenith Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Zenith Projection Television Expert? Answer questions, earn points and help others
