Question about Maytag Performa PAV2200
Goes of balance. even with small load. it walks across the floor. clothes seem to gather to one side.i have leveled this machine, but no luck
  • 784 Answers
There are 8 springs in the bottom tube to hold on the chassis. If some of them broken, it may cause this problem.
Posted on Jul 03, 2009
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My front load washer "walks across the tile floor", it is level, what can I do
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer tub vibration on spin cycle--machine will walk across floor
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is istalled.
Jan 01, 2010 | Maytag Washing Machines
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Spins off balance
Hello kel_lyn_eve,
Because your washing machine is so heavy, when it's not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine.
Your washing machine has adjustable, front leveling legs with a lock nut. You adjust the leg to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
Some machines have adjustable leveling legs in the rear also, and you can adjust them in the same way. Keep the machine as close to the floor as possible--the lower it is, the less likely it is to vibrate.
Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | Washing Machines
My PAVT920AWW won't spin hard enough to get all the water out
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
Dec 19, 2007 | Maytag Performa PAV2200
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
295 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
