Question about Whirlpool GH7145XF Microwave Oven
Whirpool Microwave GH7145XF
We have check the breaker and power supply, they were the first thinks we checked before the inline fuse. Anymore suggestions.
  • Whirlpool Master
  • 9,098 Answers
So is it dead? (No life, no beeps, no lights?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open.
When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
See our listing here on FixYa:
Let us know if you need more help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
Quit working circuit breakers are ok where's the fuse located?
it is an inline fuse between thepower in and mag tco, check hv capacitor for a short
Feb 05, 2010 | Jenn-Air JMC7000 Microwave Oven
No power to the oven.. outlet that it is plugged into is ok. is there an inline fuse or could the power supply be bad?
There are two fuses inside the unit, a high voltage fuse as well as a slow blow fuse, you may need to replace these, but as well as that you may need to check the high voltage capacitor as well as the transformer if replacing the fuse's dont solve the problem. Good luck.
Nov 04, 2009 | Maytag MMV1153A Microwave Oven
No Power
Remove cover. Check that the fuse is good, if it is good, check power from power supply to main board.
Oct 29, 2009 | Sharp R-316FS Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
133 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
