Question about HP LaserJet 4250dtn Printer
4250 printing problem
Printer still asks for legal paper and prints after all settings are set to letter.
hit button to continue prints correct on letter.
can i bypass this function?
  • HP Master
  • 691 Answers
Make sure you have the paper tray guides pushed up far enough.
Print a configuration page by the printer panel and verify the tray settings are correct. If they differ, check the fences are pushed up and ensure the tray lever is set to STANDARD not to CUSTOM.
If the printed paper tray settings differ to what is actually set, you may have a faulty paper tray width sensor. If you still have trouble try the Restore Factory Settings Option. Remember to note any IP info if the unit is attached to a network.
Posted on Nov 09, 2007
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
The printer says Load MP feeder B5. how can I fix this.
Several options here:
1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
Link to the user manuals for this machine : click here
Oct 19, 2010 | Lexmark T632 Laser Printer
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
Prints off the paper
Check the settings on the printer itself. It may be set to legal and this might override the properties settings. It probably is not printing duplex because it is waiting for the other 3 inches of legal.
Aug 03, 2009 | HP Photosmart C7280 Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Jun 19, 2007 | Xante Accel-a-Writer Laser Printer
HP LaserJet 4250dtn Printer Logo
82 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
