Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Fix main bearing
How to remove locked bearing
    Brigadier General:
  • 3,006 Answers
On every front-loading washing machine which I've replaced the main bearing on, it's normally removed and refitted using a suitable sized drift and a club hammer. Most of the time i find a trusty one foot length of scaffold tube which is in my toolbox does the trick.
If the washing machine has a polypropylene outer drum rather than a steel one then it's rare that the drum doesn't break whilst attempting the repair. On these types I've usually fitted a used drum from a scrapped machine, or more frequently just replaced the entire machine with another used machine which has been thrown away with a silly little problem like a blocked or broken pump.
Posted on Jul 02, 2009
Why is the crank locked up won't turn even if I turn it by wrench
could be seized piston/rings
seized big/ main bearings
seized gear input shaft bearings
looks like it is a pull down and rebuild
remove the plug first to see if there is coolant on top of the piston and causing a hydraulic lock--if water cooled engine
Oct 05, 2016 | Motorcycles
1996 NISSAN MAXIMA 3.0 LTR ENGINE IS LOCKED UP. WHATS THE CAUSE AND HOW DO YOU FIX THAT PROBLEM
there are several reasons
seized big end/main bearings
dropped valve or insert
broken rings
bent conrod/s
fuel/ water on top of a piston on compression stroke --remove the plugs
pistons jammed in cylinders from overheat
broken flexi plate in bell housing
failed torque converter
broken timing belt/chain
external unit ( power steering pump,ac compressor ) locked on drive belt
as you have not bothered to give any previous warnings before it locked up ,then take your pick
Sep 11, 2015 | Nissan Cars & Trucks
How to remove rear main seal from a 76 mercury monarch
Remove the oil pan. Remove the rear main bearing cap. Loosen the other main bearing caps. Using a special tool that resembles a chinese finger lock pull out the top part of the seal. It's a "rope" seal. Install the new seal in the block and the cap. Replace rear cap, torque all the main bearing caps to spec. Reinstall the pan. This job is pretty big for a novice - I don't recommend you try unless you have unlimited patience.
Jun 23, 2014 | Cars & Trucks
How to change rod and main bearings in 79 305
engine should be removed ,but can be done in frame.pan must be removed,loosen all main caps, remove one a a time .upper bearing half can be popped out with a small punch pushing against the bearing half,from the opposite side from the lock tab. oil crank side surface,and reinstall.rods the same way, crank the engine to get them to bottom. good luck
Apr 07, 2013 | 1977-1979 Chevy Pickup C/K Series Radiator...
Pedals are locked won't spin foward but will spin backward
see the following steps, and fix it. God bless you
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Nov 28, 2012 | Nautilus R514 Recumbent Bike
What is the difference between standard size main bearing and oversize main bearing. Which is best for the 5.4L V8 engine
thats a good un? ok standard bearings are a standard size,,,over size bearings are smaller in the center to make up for the metal that has been removed from when the bearing was re-fased
ie: ground down to smooth it off so its flat again,,,,,now you can fit oversized bearings on a standerd bearing becouse they would be far to tight and would lock the bearing up,,,,so you need to re-grind the bearing serfice or fit standerd bearings back in,,,only if the shaft is a good one?
i hope this has help you out
Nov 28, 2010 | 1997 Ford Expedition
Need exploded view of 1995 dodge 2500 left front u-joint removal process. How does main bearing race come off?
FRONT DRIVE AXLE Hubs and Bearings REMOVAL & INSTALLATION Models 44, 60, 70 and 80 with Manual or Automatic Locking Hubs
  1. Raise the vehicle and install jackstands.
  2. Refer to Manual or Automatic Free Running Hub Removal and Installation and remove the hub assemblies. Fig. 1: Remove the outer locknut on the Model 60/70 front drive axle 88477g63.gif
  3. Remove the wheel bearing lock nut, using a hub nut wrench.
  4. Remove the lock ring from the bearing adjusting nut. This can be done with your finger tips or a screwdriver. Fig. 2: Exploded view of the front hub retaining hardware 88471109.gif
  5. Using a hub nut wrench remove the bearing adjusting nut.
  6. Remove the caliper and suspend it out of the way (see the brake section).
  7. Slide the hub and disc assembly off the spindle. The outer wheel bearing will slide out as the hub is removed, so be prepared to catch it. To install:
  8. Carefully position the hub and disc assembly on the spindle.
  9. Install the outer bearing cone and roller, and the adjusting nut. NOTE: The adjusting nut has a small dowel on one side. This dowel faces outward to engage the locking ring.
  10. Using a hub nut wrench tighten the bearing adjustment nut to 50 ft. lbs. (68 Nm), while rotating the wheel back and forth to seat the bearings.
  11. Back off the adjusting nut approximately 90°.
  12. Install the lock ring by turning the nut to the nearest hole and inserting the dowel pin. NOTE: The dowel pin must seat in a lock ring hole for proper bearing adjustment and wheel retention.
  13. Install the outer lock nut and tighten to 50-80 ft. lbs. (68-108 Nm). Final end-play of the wheel on the spindle should be 0.001-0.010 in. (0.025-0.25mm).
  14. Assemble the hub parts.
  15. Install the caliper.
  16. Remove the jackstands and lower the vehicle.
Model 44 With Full-Time 4-Wheel Drive
  1. Remove the wheel cover.
  2. Remove the cotter pin and loosen the axle shaft nut. Fig. 3: Remove the wheel bearing adjusting nut from the Model 44 front axle 88477g64.gif
  3. Raise the support the front end on jackstands.
  4. Remove the wheels. Fig. 4: Exploded view of the Model 44 wheel bearing adjusting nut, retaining washer and locknut in their correct relationship 88477g65.gif
  5. Unbolt the caliper and support it out of the way. DO NOT DISCONNECT THE BRAKE LINE!
  6. Remove the inboard brake pad.
  7. Remove the axle shaft nut and washer.
  8. Through the hole provided in the rotor, remove the six retainer bolts.
  9. Position pull C-4358, or equivalent, over the wheel lugs and install the lug nuts. Tighten the main screw of the puller to remove the hub, bearings, retainer and outer seal as an assembly.
  10. Insert a prybar through the U-joint and wedge the shaft inward as far as it will go. Make sure that it is wedged securely and can't be moved.
  11. Install the hub, rotor and bearing assembly and tighten the retainer bolts to 30 ft. lbs. (40 Nm) in a crisscross pattern.
  12. Install the brake adapter. Tighten the bolts to 85 ft. lbs. (115 Nm).
  13. Remove the prybar form the U-joint.
  14. Install the axle shaft nut and tighten it to 100 ft. lbs. (136 Nm), then continue tightening it to align the cotter pin holes. Install the cotter pin.
  15. Using the lube fitting, fill the knuckle with NLGI, Grade 2, multi-purpose EP grease until the grease is seen flowing through the inner seal. Fig. 5: Lubrication fitting location on the rotor top hat 88477g69.gif
  16. Install the inner brake pad and caliper (see Section 9).
  17. Install the wheels and tighten the lug nuts to 110 ft. lbs. (150 Nm).
Nov 05, 2010 | 1995 Dodge Ram 2500
LG WM3431HW: I need to remove the interior main bearing from the plastic tub. It seems very fixed in there, and I wonder if it uses Lock-Tite or if it's just corrosion keeping it in. How can I get it out...
To remove the interior main bearing from the plastic tube.
look at it very well, there are screws which hold it firmly. get a screw driver to loose this screw and pull it out easily.
Thanks for contacting Fixya.
Jul 08, 2010 | Kitchen Ranges
How do you change rear bearing on 2000 safari?
The rear axle bearing? I'm going to presume that's the bearing you're talking about and not the rear main bearing, so please take that into consideration if you would
You're going to have to jack up the rear of the van, remove the tire and drum. Then you have to place a drain pan under the rear differential and remove the cover. After the cover is removed spin the rear axle (the one with the tire off) to locate the pin in the very center of the differential. On the right side you will see an 8mm (5/16) bolt head.
When you remove the locking bolt (the 8mm) and slide the pin out DO NOT SPIN THE AXLE WITHOUT THE CENTER PIN IN PLACE. Push in on the axle with the bearing to be replaced and a "C" clip will fall out of the differential. SLIDE THE CENTER PIN BACK IN and screw in the locking bolt a few turns. Once the "C" clip slips out, you can pull the axle out. If you don't have a bearing puller, it's best to rent one. Insert the bearing puller and pop the bearing out.
Apr 06, 2010 | 2000 GMC Safari
How do I remove the C-clips on a 10 inch rear diff with lock-up . I need to replace the axle seals. I have removed the lock pin and the main spider gear pin but can't seem to remove the centre piece that...
once the pin is out, push the axle in towards the middle of the car, the clips may now come out, even fall out maybe. remove the clip, then pull the axle out. be sure that the axle bearing surface is good, any pitting or grooves and the axle and bearing and seal will need replacement.
Sep 25, 2009 | GMC Savanna Cars & Trucks
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
132 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
