Question about Kitchen Ranges
Changed light bulb, broke the oven :-(
So I stupidly unscrewed the light fixture in my GE Spectra JBP78W0B4WW oven (thinking that's that I had to do to get that pesky light cover off). I received a popping noise, a bit of smoke, and a dead oven for my mistake (no lights, no displays, no burners, no nothing).
I did some searching online and discovered that a ruined control panel may be the culprit, so I got a new one and replaced the old one. However, my dead oven is still dead.
Can someone help this hapless shmoe diagnose what to check next? Is there anything else that I can do to keep this from being a $500 lightbulb? Any assistance is appreciated.
Thanks in advance for your help.
  • Dan Troutman Jul 02, 2009
    I immediately replaced the lamp socket. I hadn't "taken apart" anything but unscrewing the two side screws when the "popping" and "smoking" occurred, so I replaced the screws right away.
    I removed the back cover, and saw no damage to the socket wiring. There were no other damaged wires between it and the control panel. HOWEVER, the insulation around the two wires connecting to the top oven heating coil was scorched (a little brown). Would this shut down the entire oven electronics?
    Have not checked the outlet, but did check the breaker to make sure that wasn't the problem. I'm a newbie to electricity repairs (thus the creation of this problem in the first place!) I do have a multimeter, but have never used it, so I'll see if I can figure that out.
    No other wiring shows signs of burning except the above mentioned heating element insulation.
    Just curious as to how unscrewing the light fixture caused this in the first place? Any ideas?
    Thanks so much for your help.
    Dan
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Did you get the lamp socket reassembled? Inspect the wiring to the socket for burned/melted insulation/wires? Check the circuit breaker that feeds this circuit? Check power at this outlet with a meter? If good, check the area of the pigtail (the cord) connections for burned wiring.
I did this same things just today with my oven.. I am a woman trying to fix a man's problem.. I really didn't know HOW to change the lightbulb, but I took out the two screws and started pulling it out and heard the *pop* sound and saw smoke and sparks... then it stopped, so I replaced the fixture and screwed in the two screws.. Now, I am a mother of three and worried to go to bed ... thinking that this may start a fire overnight. Is this something I should be worried about? The oven still works and so does the rangetop.. Someone, please post on my issue before I go to bed... I'll be waiting up to hear.. Thanks!
Posted on Aug 23, 2010
    President:
  • 1,136 Answers
Hi, Well first thing to check is if it is getting 240V to the wall outlet. If it tripped off when the oven shorted, you might only be getting 120V if any. Turn the breaker off and back on a copule of times and see if it helps.
If it is getting voltage, check the block assembly the cord bolts to and see if there are any burnt wires there.
There are no inline fuses on this model. Makes sure all you wirs are ok.
I hope this helps you. please let me know if I can assist you further,
Vic
Posted on Jul 02, 2009
  • Victor
    Victor Jul 03, 2009
    Dan, It's amazing how trying to fix one issue can lead to others. I hope the popping noise you heard might have been inside the outlet. With the breaker off, remove the outlet cover and check for a bad/loose wire.
    With you multi neter, You can check continuity on the cord as well. Unplug the cord and put one lead on the end that connects to the oven. Put the other end on the plug end adn see if the cord has continuity.
    I will be here for a while so, let me knwo if I can help further.
    Vic
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
GE JTP20 oven. Do I need to replace light fixture after spark from a short?
First, no First, no First unplug the range after you gently scoot away from wall. Then check youy main circut breaker for house to see if you tripped fuse. Then with stove still unplugged remove back access panel, look to area where light goes into oven. Check again and make sure oven is unplugged, then repair the wire by splicing wire with new wire line splice purchased at your nearest local auto parts store, sales person can show how to install. THEN plug in to see if you can see the light!
Joe Don
May 25, 2012 | GE JTP20 Electric Single Oven
Inside of front double burner not working on my spectra GE Range model number JBP78W0B4WW
this is a 9" 2600 watt element and may have to be replaced, here is the part #WB30T10050. if the element checks out ok, you may have to replace the infinite switch and this is the part #WB24T10011. hope this helps.
Oct 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
How do you change the oven bulb in a GE Profile Convection oven?
Unplug or flip breaker to the range. Remove wire around glass bulb protector by sliding one side out of clip while holding onto glass protector so it doesn't fall into the oven and break. Unscrew old bulb, replace with new one. Hold glass bulb protector over the bulb and hook wire back into its clip. Voila! Back in business. (I didn't unplug it, but discovered that you can't turn off the bulb, so it shines in your eyes while the oven door is open. Also, very stupid thing to do, since the bulb could very easily have broken in my very clumsy hand and given me a bad shock. So do it right, and unplug!)
Jun 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Scrubbed the gas fixtures on stove top, won't light
this is something I do not recommend you do yourseelf, but there is a adjustment screw on the front under the panel near the knobs little screw that can be adjusted
Feb 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
Kitchen Ranges Logo
383 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
