Question about Saeco Talea Touch 14-Cup Coffee Maker
How to dsimount housing (sides) I need to open
How to dsimount housing (sides) I need to open the main box
I have a problem with Talea Touch (water).I remove the bean container, but after It is impossible for me to Lift the top cover at the back up. I try but It's seem blocked. Could you explain more or send me a picture.
My email address is tlafont@laposte.net
Thank you for your help
Thierry
Posted on Mar 04, 2010
  • 20 Answers
Hi..remove the bean container and then the coffee spout with T10 screw driver.
Lift the top cover at the back up the release the clips...then put the finger under the front cover in the middle section and pull forward and slide over the spout area to prevent chipping the frame of screen.
Then you will see the T10 screws holding the sides.
Posted on Dec 16, 2009
Your question about Cars & Trucks has been posted.Had a well water pump installed and now one side of the house power is not working could the pump cause something to be grounding out the circuit?
Possible, but not likely. Simple to check, really. Just open the circuit breaker in the main box for the well pump. Then reset the main house breaker. If power is still missing to one half the house, then most likely you have an issue with the supply lines coming in. If you have the ability, open the house main breaker and with a voltmeter, check the two lines coming in, first each to return, and then across the two. If it is a US household, each side should be 110-120vac to return and 220-240 VAC across the phases. My guess is you lost one phase coming into the house. If the power is bad into the top of the main, contact your power company to have them repair their input lines.
Nov 21, 2015 | Cars & Trucks
My 1987 Nissan se v-6 truck is leaking oil really bad is it the rear main seal
where is it leaking from
in front of the b ell housing--- sump gasket
out of the bell housing drain hole --could be rear main seal or gear box input shaft seal
from down the side of the motor in front of the bell housing--- rocker cover gaskets
is the sump over full
Sep 16, 2015 | Nissan Cars & Trucks
Coleman heater 3500a820 lots of smoke and now only blower works no heat
I am not sure about the heater type, but likely the heater element controller shorted out or the heater elements shorted - hence the black around where the wires go into the electric box. If you're lucky, the wires shorted to the side of the box. With the power off, open up the electrical box, mark which wires go where, remove them from the board, remove the wires from the electric box, then using electrical tape, tape up the exposed ends of the wires. Spread them out so they do not touch each other. Turn on the 60 amp breaker - if it trips, then your wires are bad and need replaced. If it does not trip, then the problem is with the heater. Do not let anyone near the wires when testing them! Don't forget to turn off the breaker if it does not trip. Again, turn off the breaker if it did not trip.
Oct 18, 2012 | Coleman Heating & Cooling
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
How do I change a blower motor in a chrysler Town and country
Hello, to change the blower motor resistor follow this steps:
  1. Disconnect and isolate the battery negative cable.
  2. Open the glove box.
  3. Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening, then roll the glove box downward.
  4. Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the blower motor resistor from the resistor connector receptacle.Blower motor Resistor
  5. Reach through the glove box opening to access and disconnect the blower motor pigtail wire connector from the resistor connector receptacle.
  6. Remove the two screws that secure the blower motor resistor to the evaporator housing.
  7. Remove the blower motor resistor from the evaporator housing.
Thanks
Aug 25, 2010 | 2006 Chrysler Town & Country
I have a 200 amp service panel i have a 100amp
Theres a few different ways to set up the secondary panel. The most efficient way, in my opinion, would be to set it up as a subsidiary. This is a really great way to allow power to be shut off for sections of a house instead of killing everything. This requires wiring it to the main panel on a breaker which will serve as the main for the 100amp subsidiary. Obviously this will require that a comparable breaker be installed in the main 200 amp panel to support the new subsidiary 100 amp panel.
Here's where it gets tricky and you really should either consult or contract a licensed technician. Because the amperage rating does not dictate the amount of power that is supplied to your house on the primary line you are essentially using the new box as a splitter. The danger in this is that just like any common electrical outlet, the more stuff you plug into it the more likely you are to overload the circuit and risk catastrophic failure, like a house burning to the ground or worse.
Knowing that your panel is side by side, you should be fine with #2 AWG, I would confirm electrical code before installing and ensure that grounds are diverted to the main panel to avoid the risk of running live current through the otherwise 'safe' ground.
If you are installing the panel to increase the amount of breakers it is probably safe to assume that there has been some previous work done that fills up the main panel. I would strongly encourage you to talk to an electrician about your needs and the changes in your house that require the additional breaker slots. There is a certain amount of artistry involved in 'designing' the house and you could probably accomplish the same end result with one panel and a more efficient wiring plan.
Mar 08, 2010 | Your One Source Homeline Load Center, 200...
Replace pollen filter in 2008 honda odyssey
The pollen filters are located in the HVAC box behind the glove box. While holding the glove box open, unclip the glove box damper (left side). Then remove the glove box stops on each side, flip the glove box down. Pull the pollen filter housing from the blower unit by releasing the clips on both sides. Replace the filter in the housing make sure the arrows printed on the new filter are pointing down. Reinstall all removed parts. -hope this helps.
Mar 02, 2010 | 2007 Honda Odyssey
I need to replace my old bath fan, I removed the grill and have no idea how to remove the fan assebly. Th efan is about 25 years old
There should be one or two screws somewhere in the box. This will allow the fan housing assembly to be removed from the base box. When the screw(s) are removed the fan housing may have to be pried down a bit. There are usually two tabs on the opposite side of the screws which allows a hinging type motion to swing the unit out. The main housing will have a woodscrew attaching it to a nearby cieling joist . You will have to remove the output host from the box also. Then you can replace whole unit with better unit,
Feb 19, 2010 | Dryers
97 ford e150 van inside windshield steams up. is
the heater core is located in the black box that is in the pictures (see below). To get access to it, you will need to remove the blower housing. The blower housing will separate from the main HVAC box, and will give you some space once it is out. Then we need to wrestle the main box loose from the firewall. That means dealing with the A/C pipes, heater hoses, vacuum hoses, mounting stud nuts under the hood and mounting bolts inside. Once the box is moving, the dash needs to "get floppy" so you can pull back the passenger side far enough to give the main HVAC box enough room pull away from firewall, and to "roll" back towards you. At this point the heater pipes will be visible, and the cover that contains the heater can be removed. It's a big job. Your car has A/C. The description in the haynes book is for a car w/o A/C. If you're not comfortable with plastic dash board removal, this job is not for you
Feb 19, 2010 | Ford E-150 Cars & Trucks
Well on my 300m the heater and a/c dont turn off even if i press the off button
If you have the automatic controls you'll need to replace the blower power module behind the glove box.
1) Disconnect and isolate the battery negative
cable.
(2) Open the glove box.
(3) Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening then roll the glove box downward.
(4) Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the power module from the module con-nector receptacle.
(5) Reach through the glove box opening to access and disconnect the blower motor pigtail wire connec-tor from the power module connector receptacle.
(6) Remove the two screws that secure the power module to the evaporator housing.
(7) Remove the power module from the evaporator
housing.
Jan 15, 2010 | 1999 Chrysler 300M
Saeco Talea Touch 14-Cup Coffee Maker Logo
485 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
