Question about GE Refrigerators
Have a TBX25PC Top Freezer Ref. Just pulled it out, found it has been leaking water near back on hardwood floor. checked ice maker hose, not the problem. Drip Pan appears dry. Any ideas
yalmer
  • 552 Answers
SOURCE: frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Posted on Apr 22, 2008
  • 531 Answers
SOURCE: drip pan is overflowing, ice maker works, no water
is not the filter water line frozen in refrigerator or water valve check and see if refrigerator door (ajar)
Posted on Apr 07, 2009
lojacksdad
  • 121 Answers
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
What does the tubing from the ice maker water valve go into when you feed into the funnel of the ice maker?
There is probably Ice forming in the end of the water line. I fought this battle for a long time. Then I found the answer. The Freezer temperature is probably too cold. I have read that the temperature must be set to between 0 and 4 degrees. WRONG. It should be colder than 10 degrees and I have found best results with the freezer set to 6 or 8 degrees on the control panel. To test this. Take a blow dryer and heat up the area where the water comes into the icemaker. Use caution it is possible to melt some of the plastic in that area. Then, set the freezer temp to 6 or 8 degrees. It will probably work fine.
Jan 08, 2017 | LG Refrigerators
Frigidaire refrigerator with ice maker leaks water
Apr 22, 2008 | Refrigerators
I have a great model # tpx24srya-bs refrigerator and when the icemaker is on it leaks water from I don't know where. When Ice makers off there's no leak.
There is a solenoid valve and a plastic water hose that connects to the ice maker. Looking at the rear of the unit you can see where the plastic tubing connects from behind the air shield into the solenoid. A second hose connects from the solenoid to the water inlet connection on the wall. The connection to the wall is probably OK because it would leak with the ice maker off if it did,
It is the hose that goes up from the solenoid through a hole at the upper right top that is the most likely culprit.
Look for water coming from a failed hose at or near the solenoid valve connection where the ambient heat is the highest. It is the heat of the hot air that deteriorates the hose. Replace the hose.
After ten years many are known to fail?
"Protect floor before rolling filled refrigerator out from the wall!" The weight will scar the floor from the wheels including hardwood floors!!"
Hope this helps?
Nov 07, 2016 | Refrigerators
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
I have a Sub-Zero 550 bottom freezer Ref. It is leaking water all the way back & center beyond the drip pan. I have disabled the ice maker by removing the ice bin and it is still leaking water. I...
There is usually one hose and it could have been moved so its not in the pan any more, you should be able to see it near the pan, from the front with the grill removed, use a coat hanger and hook it back into position, if the pan is over flowing, than that's another problem
Jun 26, 2011 | Sub-Zero Bottom Freezer Refrigerator
Leaking water
Dear Elizabeth,
please rate this following solution if it mends ur needs,else choose fixya.
please perform the following checks,
Water on floor outside of freezer
Water inside the freezer
  • Check for a clogged drain tube
  • If you have an ice-maker, check freezer and ice-maker for level
please rate this following solution if it mends ur needs,else choose fixya.Thank you.
Dec 17, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Ice forming in Freezer Basin
Hi. That is the only drain for the evaporator water during the defrost cycle. Take the back aluminum cover off again and pour hot water into the drain. If it won't drain, take a hose and put it over the drain and blow into it. That will remove the sludge in the trap and it will drain good now. I've seen alot of nice hardwood floors damaged with this problem. Good luck, Mack
Feb 02, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
