Question about Canon XL1S Mini DV Digital Camcorder
Lens failing to function properly
Earlier tonight I was filming a function with my canon xl1s and before filming began, it prompted me to check the lens and faded to black. I turned the camera off then back on a few times; same result. I removed the lens and reattached it probably six times, giving me about three diffent results upon reapplication. 1. blurry 2. no zoom 3. both. I am still unable to zoom or focus using both the camera and the lens. I was able to use that camera, but only stationary and no zoom or additional focus. I have since tried it at home and the problem persists!! i have XL1's .when zoon in to the subject it does not make any problem.but when i try to zoom out it does not focus the subject.steplizer spins without pressing any button.
  • 515 Answers
Yes, this is a strange issue. Have you dropped the unit, or maybe 'bumped' it or anything similar. I know alot of times, people like to 'hit' their unit, to get it to do things (like eject tape). What people don't realize, is that these machines are prone to damage when hit hard enough (just like anything else).
In any event, this is not an misconfiguration issue, and you won't be able to fix it. You would need to bring it in to a qualified service center for an estimate. Be sure to shop around to find the best price and service. Since parts for these are not cheap, and they are labor intensive.
Good luck.
Hope this helps some.
TWEAK A/V LAB
Posted on Nov 09, 2007
I am using a Canon A1, and the film advance lever is stuck and the meter does not show. It was just working a minute ago.
Rewind the film and try 'dry-firing' the camera, checking to see if the lens is working properly. May be a bad contact between the lens and the body, may just the the film has loaded slightly on the huh.
Oct 02, 2017 | Canon Photography
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
No matter how i record i seem to have less than perfect qaulity that i would expect from my xl1s camera. It seems fuzzy or grainy at all times whether great or poor lighting. am i missing somehting in the...
Are you operating with the selector knob in the green "preset" mode or one of the custom modes? That camera can be set up ten ways from Sunday and it's quite possible that it's in a mode that is damaging quality.
Also, check rear element of lens and sensor for debris.It's got a removable lens and might be dirty. Be EXTREMELY careful cleaning the sensor, Seek guidance. Personally, I've never touch a sensor. A puff of air should do it. Don't touch it with anything. If it looks clean, leave it alone.
Mar 22, 2010 | Canon XL1S Mini DV Digital Camcorder
Earlier tonight while I was driving my '05 Colorado began to steer rather rough while I went around a curve. I checked the power steering fluid and it looked to be full. What do you think could be the
Mine did the same thing. I took it to the dealer (always get the extended warranty). They replaced the pump. Problem still there. They then replaced the rack and pinion. Problem solved.  Sorry, this might be a big one.
May 02, 2009 | 2005 Chevrolet Colorado
CANON XL LENS CAP FOR 16X ZOOM LENS
According to its specifications, this lens can use a 72mm filter. So you should be able to get the type lens cap that clips into a 72mm filter to work. Such as the one shown here. I'd recommend you go to a local camera store and try one to make sure it works.
Feb 11, 2009 | Canon XL1S Mini DV Digital Camcorder
Problem with Canon XL1S lens
Definitely sounds like there is a problem with the lens. You might be able to get a new one, from canon, considering they have a lifetime warranty on all of their Lenses. Otherwise, it seems that you will have to spend some money.
Feb 11, 2008 | Canon XL1S Mini DV Digital Camcorder
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Canon lens not functioning properly?
All those contacts are cleaned?
New battery, not old and charged, right?
atdlee@netzero.com
Dec 15, 2007 | Canon XL1S Mini DV Digital Camcorder
Camera lens
It sounds like a CPU chip incompatability issue. Sigma has that problem sometimes but are usually very good about rechipping at no cost (at least for Nikon-mount lenses). What did they say when you asked them?
Oct 16, 2007 | Canon 16x Manual Servo for XL1S
Possibility is two. 1. If the lens contact to the body is not good so make sure the contacts are clean and position is locked completely. 2. 90% of the solution comes from repair on Main circuit in the lens. Good Luck. For further assistance go to www.camerarepairjapan.com James.
Aug 26, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
