Question about Pool & Spa
Wiring up a pump with capacitor and pressure switch
Recently I bought a Pentax jet pump for our appartment pressure drop problem. The pump works but as it stops by the pressure switch or manualy, the fuse blows !!
I actualy am not sure if it is wired up curectly with a capacitor and I am using it with a pressure switch but unfortunatly I don't have the instruction manual on how to do the electrical wiring.. any way I connected the fase and null to the wires that are connected to the capacitor as well but still there is a terminal namely SIGNAL. I didn't find instruction diagram anywhere.
Thanks for answers,
Maziar
  • 990 Answers
This is a confusing explination of your problem. Elect is dangerous and should be left to profectional's
Posted on Dec 16, 2009
Pump safety switch
The wiring information is in the manual. Are you calling the pressure switch a safety switch?
Jul 14, 2013 | Flotec Corrosion Resistant Shallow Well...
Pressure switch no longer making contact
First try to clean the contact points, maybe it's help
Mar 26, 2013 | Flotec Pressure Switch 40/60 TC2153
DAB Jet 62 won't pump
U might've burned the start capacitor also. If u don't see one on the exterior,check inside the end bell (cap) of your motor. Do u hear the motor hum? If not there a likelyness u burned ur motor
May 26, 2017 | Plumbing
What is the reason why you hook up the pressure switch to the jet pump..rather than the tank??
That is really just for convenience...
They sell it as a package that is ready to install...
I have already removed the pressure switch from the pump installed them in the conventional manner...like a submersible pump...
The problem with that is that there usually is then no make up bax for the wiring, so you will have to rig something there...
You also will have to remove the fitting for the hose going to the switch and plug the hole with a pipe plug...
Other then that it will work just fine...
heatman101
Apr 06, 2011 | JET 708526 JPM13 13Inch 112 Horsepower...
My pump builds pressure to 60 psi but will not go any hire for the shut off what can be the problem
most jet pumps have a pressure switch to regulate cut in/ cut off pressure. Normally 40/60 psi. The pressure switch should be located at the rear of the pump where the wiring enters. First disconnect the power supply to the pump. Remove the cap where the wiring enters. On the inside of the cap there should be a diagram showing how to alter the cut in/ cut off pressure.
Jun 13, 2010 | Jet Plumbing
Why is the pump cutting in so much
Check your water pressure tank air pressure, turn off pump, drain off all water pressure and using a air pressure gauge check pressure at the schrader valve on the water pressure tank. It should be 2 lbs below pump cut-in pressure, they come factory charged at 30 PSI...works for most residential systems. Most likely you have a bad bladder in pressure tank.
Other possibles are a broken line between pump and pressure switch/pressure tank or bad pressure switch.If you have a pressure gauge on the water system(should have one near pressure switch) see if it is cycling at the right points if it is the switch is good. If pressure is dropping with NO water uasge in house you have a leak.
Most likely a bad pressure tank bladder is the problem.
Oct 24, 2009 | Jet Plumbing
My well keeps running i replace the pressure switch and the well starts working properly this happens every 6 months i have replaced the well , jet , and bladder tank why does this keep going on
by keeps running I assume that the presure switch doesn't cut out at the desired pressure and replacing the pressure switch solves the problem probably the contacts in the pressure switch are becoming welded if it worked for years and then this just started then if the pump has a capacitor start ( box inside the house between the pressure switch and the pump wires) you may want to cosider replacing that component and well your poking around verify that the rating of the pressure switch matches your pump requirements amps volts ect..
Good Luck
Oct 08, 2009 | Plumbing
Installed new pump and tank. Works fine until I do laundry.
There is dirt in your presure switch. Take apart switch clean diaphram and reinstall diaphram upside down. That should do it.
Sep 03, 2009 | Flotec Corrosion Resistant Shallow Well...
Pool & Spa Logo
294 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
