Question about Panasonic SC-HT670 System
How do I align the trays on my Panasonic SC-HT670?
No esta en sincronismo nesecito el diagrama de los engranajes para sincronisarlos
Posted on Jul 15, 2009
My system says INIT please wait and the cd/ dvd trays are out of line i tinkle a little with electronics and feel that if i knew a little more about this problem I can fix it myself,especially due to high...
  • First you to pull out the DVD tray assembly and check to make sure there is not anything that has broke inside there. Make sure nothing is blocking the trays from moving.
  • Now pull the side cover off. There is a spare gear on the top of the DVD tray assembly. You will take that and place it in the two holes at the bottom of the player. This will allow you to manually adjust the trays. If you don't have this gear you can align the tray manually but it has to be real perfect.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 26, 2011 | Panasonic SC-HT670 System
My dvd player is dead on my sa ht670 panasonic dvd player home theater. Is there any way to still use the other functions like aux? i do no need the dvd player just want to use the theater for sound. I...
Maybe if you ask it to OPEN the tray as soon as you turn it on and leave it that way it might move on to other functions. A hands-on tech would have to lay hands and eyes on it otherwise.
Jul 04, 2011 | Panasonic SC-HT670 System
I am having problems with my SA-HT670 it is reading error code INIT and then WAIT. The 5 disc changer will no open and close properly
The CD loading mechanism is not resetting properly. When powered on, the entire mechanism goes through a startup alignment sequence. This is to be sure that the unit is in a known position and state. The init indication is for the "electonics" reset portion, the wait message should be present while you hear the mechanism move. The most common cause of this is a slipping belt or a jammed CD. Be cautious about trying to repair this yourself. It is easy to damage the gearing inside or to get it out of aligment. There is a good possibility that this can be repaired with either no parts or with a $3-$5 belt.
Dan
Nov 02, 2010 | Panasonic SC-HT670 System
Same problem
You might have a broken tray drive belt. Take off the outside cover and look for a small black rubber belt or its pieces.
Jun 22, 2009 | Panasonic SC-HT670 System
Says wait, won't play dvd's at all
Yes you are right, this will happen only when tray mechanism is not working at that time lense will try to read but it will be still under wait condition,
to resolve your issue you need to replace entire tray with lense set to work properly.
Mar 29, 2009 | Panasonic SC-HT670 System
Jamed
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Nov 22, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670
Sep 24, 2007 | Panasonic SC-HT670 System
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
Sep 01, 2007 | Panasonic SC-HT670 System
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670 System Logo
526 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
