Question about Jenn-Air 30 in. JGD8430A Gas Cooktop
Recent install, using lp kit, in use it seems like we smell lp gas during use, flame is not right, and seem to jump toward the vent, and around controls. Definitely not right, what should I check? I checked regulator, looks ok according to directions, havent checked orafice sizes yet, but choke is installed on front right burner.
    Novelist:
  • 222 Answers
Try to repalce the regulator.sometime the problem is not in unit? in regulator or if u have other regulator try to use then check it. if same thing again,call an expert tecnician to check the gas line & the unit.do not try to repair by it ur self ocz if hard & itr danger
Posted on Jul 04, 2009
  • gerbee gomez Jul 04, 2009
    try to repalce the regulator.sometime the problem is not in unit? in regulator or if u have other regulator try to use then check it. if same thing again,call an expert tecnician to check the gas line & the unit.do not try to repair by it ur self ocz if hard & itr danger
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
The gass burners seem to not give as much flame as they used to.
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Jan 18, 2011 | Jenn-Air JGC8536 Gas Cooktop
The flame on my Ikea DATID Hob is huge and has a lot of yellow flame. It makes my pots black, and is difficult to regulate because the flame is so big.
Hi, it really sounds like your cooktop is not set up for your type of gas. More than likely, it is set up for Natural gas and you are using Propane. You need to convert to LP using the kit. The only thing you have to change is the orifices.
Jan 18, 2010 | Cooktops
How can you tell which fuel a gas cooktop is set up for?
the gas regulator has a round "plug" in the middle of the top and one side is marked nat an one is marked lp you can tell which fuel the regulator is setup for by inspecting this plug. the orifices for the surface burners are marked with thier sizes (.073) for instance which I believe is thousandthsof an inch. also the orifice "spuds" as they are called will often have a drop of colored paint on them to further identify them for installation in the correct burner. checkyour carburation too. if the flame is noisy and trying to shoot up of the burner you could be getting too much air. close the air off a bit till you make a pretty flame two tone blue no yellow.
Aug 09, 2008 | Cooktops
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Gas burner not getting enough gas
It sounds like a bad pressure regulator. Or it may be adjusted for LP gas. I need more information. Sometimes you can adjust it yourself, sometimes you need to buy a kit or new regulator.
May 18, 2008 | Cooktops
LP Conversion for Jenn Air CVG316 (about 10 years old)
I have the same stove and I got the LP Conversion Kit at Sears Part Direct.:
http://www.searspartsdirect.com
Thisis the Part Number for the LP conversion for the Jenn-Air CVG316B: Part# Y04100687
Hope that can help you
Eddie Rentas
Tupper Lake NY
Nov 21, 2007 | Jenn-Air Cooktops
Jenn-Air 30 in. JGD8430A Gas Cooktop Logo
113 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
