Owners manual
SOURCE: Looking for owners manual Craftsman table saw 101.02141
I tried their site and they say no parts available for that tool, They suggest that you call them direct and I have a phone number at 1-800-252-1698 and they might be able to help. Good luck
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
SOURCE: Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
SOURCE: my delta 36-650 table saw 1.5hp motor dims lights
If you didnt replace your switch ... do so now. If you did replace the switch, check your work
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
