Question about RCA 32V420T 32" TV
RCA F27442 27" TV
The picture on my TV looks really good...color, location, etc...except that the lettering on things like the ticker at the bottom of the screen on ESPN or the score boxes while watching a football game are blurred. They are actually like double vision. The picture is the same, but not very noticable while watching something like a movie. The lettering on the "Guide plus+ Gold", which the TV has, is clear. The lettering on Closed Caption is clear.
I tried adjusting the focus using the "Menu" button and the adjustment on the back, but nothing!
I finally took it to a repair shop. They say that the part it needs is on back order from RCA. I'm trying to find the part myself, but am having a hard time. The number the repair shop gave me is LA7812N...it is an IC Chip. I've been told that I have to "cross reference" that number, but am having no luck doing so.
Can you help me get that part or tell me how to cross reference it?
Thanks!!
    Genius:
  • 1,694 Answers
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
....................................................T.
Posted on Dec 04, 2007
I have an RCA model D52W23 tv and the colors are out of line
Do not use magnet on or near this set---
This set is known for convergence problems where picture looks 3 d etc and this is caused by bad connections under and around the high voltage transformer in many cases.
First thing to do is look in menu to see if "Convergence" option is still there or missing----three small parts available as a kit exist to correct that if the option is missing (all are at same place around the high voltage transformer).
Set would have to be taken apart if you are able to check things there---if not most techs familiar with this set can deal with this in the home.
the connections and parts are all right where the high voltage transformer (called a flyback) is located.
typical flyback:
Dec 03, 2012 | Televison & Video
Loss Color
I get that there is no Chroma on something but not sure in what mode or source you are speaking about. Sometimes people have trouble due to a setting being wrong or they use a really cheap video cable which can strip the higher frequency Chroma signal off of the Baseband or Composite video signal. Try a higher grade of video cable- video signals at 10MHz bandwidth do not like to go through cheap audio cables. maybe you could clarify the problem more?
Aug 10, 2012 | LG 42 42PT350 42 Plasma TV
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA 54 in projection tv shows a blurred picture
On the RCA - Color Wheel Encompass Parts Distr look up online or call them 1-800-638-3328 Other TV could have Bad capacitors pull back off if any of the caps are puffed up on top then they are Bad 1000uf 16v , usally find 2 or 3 bad
Oct 08, 2009 | RCA HD50LPW175 50" HDTV
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Screen adjustments??
On the remote, if you use the right and left keys on the pad with the OK sign in the middle, it will adjust the screen to several sizes including Cinema, 16:9, 4:3, Zoom, etc. I, personally, use 16:9 because I, like you, need to see the ticker symbols at the bottom. I hope this helps.
Sep 17, 2008 | RCA HD56W58 56" TV
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
RCA 32V420T 32" TV Logo
137 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
