Televison & Video Logo
A
Anonymous Posted on Sep 06, 2014
I need to adjust volume on craig cht745 Only the
I need to adjust volume on craig cht745 Only the speakers. I don't use the reciever. And do not have the remote that came with the package. I want to use my direct tv remote to operate speakers volum?/
Chris Frost
Level 3:
  • Master 985 Answers
  • Posted on Sep 07, 2014
Chris Frost
Master
Level 3:
Answers
985
Questions
0
Helped
217899
Points
3239
I don't think you can do what you imagine.
The Craig speakers are powered by the DVD receiver. That's how they're controlled.
1 Related Answer
Anonymous
  • Posted on Jun 16, 2009
SOURCE: Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
Craig remote cht935bt
I’m trying to Bluetooth my Craig CHT935BT but don’t have a remote
Remote code for direct tv remote to operate craig
0039,0033.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Where is adjuystment page for audio
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps you
3helpful
Volume control.have craig mp3 player cmp616f. how do i turn down volume ?
press the volume control once - the speaker picture on top should blink, then press the fwd or bkwd buttons on either side. if the speaker does not blink, press the volume control again. do not hold the volume control in.
3helpful
I have an onkyo TX-SV515 PRO receiver and the remote speakers will not turn on. The main speakers work fine but when I depress the button to turn on the remote speakers they do not switch on.
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
3helpful
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
2answers
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
2answers
Don't know how to adjust volume on remote speakers
Can I ask you something? I have the same but the remote doesn't work, and I have no sound in the B speakers. I wonder if there's something that I have to do with the remote, or there's a problem with the receiver, Thanks.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
