Question about Insignia IS-LCDTV32 32 in. Television
Insignia 42 LCD TV Blurry Picture. Computer
Computer connection: Good Picture
Cable/Air connection: Blurry picture
  • booner74 Nov 04, 2009
    Similar issue with blurry picture on Insignia 42", but fine through DVD player (S-Video). Cannot seem to get a good, clear HD picture even with using HDMI port via DishNetwork tuner.
  • Anonymous Mar 19, 2014
    service port
In order to get 1080i resolution you must use a HDMI cable or else all you will get is 780 resolution. Read you manual carefully. You have a selection of sources the TV will read from. If your using cable or satellite to get you signal then there will be a selection for that source; make sure the TV is tuned for that source. The same is true for the DVD player. If all else fails have someone else familiar with flat-screens look at it. I always recommend paying a bit more and getting the extended warranty, it's worth its weight (or cost) should something like this happen. If the TV is brand new and you have this problem, take it back and have it replaced. If the next one does the same thing then its not the TV. There are lemons in everything but these sets are usually very well tested before they leave the factory. Hope this helps but get the HDMI cable, you'll be amazed at the quality in 1080 resolution. Oh yeah, as far as the picture looking like a soap opera, welcome to the world of Hi def TV, that's normal and you'll get use to it very quickly.
Posted on Feb 05, 2012
  • 643 Answers
Tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
Whats the best picture settings for 42 lcd insignia tv
Hello
55% Contrast, 35% Color and brightness to match will give you a vivid picture to your TV.
Mar 05, 2012 | Insignia 42" LCD Flat-Panel HDTV
Connecting computer to tv using hdmi cable
Go to file setting and turn on tv out on the computer and in the menu on the tv
Sep 26, 2011 | Insignia 42" LCD Flat-Panel HDTV
I have an Insignia 42"
First, I would check the connection to see if everything is in it's proper place and plugged in nice and snug.
Second, I'd try watching something else on the TV and see how it looks, I'd also try watching something using the same cable/input the DVD player is using. If that fails, try a different cable.
If your TV checks out, and it's your DVD player, it might be time to upgrade to Blu-Ray or buy a new DVD player.
Hope this helps, cheers.
Kevin
Aug 27, 2011 | Insignia 42" LCD Flat-Panel HDTV
I have sound and picture distortion (like what happens during a thunderstorm) in my 42 inch insignia lcd tv but not during storms. started about two weeks ago, happens intermittently. driving me nuts. is...
Your probably having what cable guys call a SNR ( signal to noise ) issue. There's no way to know unless you call your cable provider. The SNR should be 32 and above with zero pre/post errors. In case you want to ask the tech what they are.
May 18, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
How to set 42" Insignia from 780p-1080p.(don't know if that's the problem)T.v. connected to satillite and still get snowy ,blurry picture..My old t.v. with satillite looked better than this new t.v
You may need to adjust the native resolution passthrough setting on your satellite tv box. Besides that you set 1080i on the satellite tv box not the tv. The tv just picks it up automatically. You may call the satellite tv company directly to ask for assistance in completing these two things.
May 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
Jan 17, 2010 | Sylvania LD320SSX LCD TV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
Have sound but no picture
I would check the connections to make sure they are good. The video connection could have gotten knocked loose. Sometimes they just come loose.
Feb 25, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-LCDTV32 32 in. Television Logo
1,048 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
