Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
F3 on Whirlpool dishwasher ADP7949
My dishwasher starts out fine, but after appr. 45 minutes it stops and shows error F3.
When I open everything seems to be okay, except it hasn't finished (no water in the bottom or anything like that), but the soapdispenser is still closed.
I do not know if these incidents are connected, but the first time it happened we came home and one of the relays had gone out (electricity to the kitchen plus more).
I hope someone can help me. :-)
    New Friend:
I assume it is most likely the heater element has failed, or wire connections from the control board to the heater have frayed (in the door hinge), or to a lower probability a fault in the PCB or thermister
Posted on Mar 10, 2013
  • 27 Answers
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Posted on Feb 21, 2011
How do I put the dishwasher into diagnostic mode?
Hello friend, thank you for your inquiry!
From the information you have provided you would like to place your Frigidaire dishwasher into a diagnostic mode. I have reviewed the dishwasher and do not show a diagnostic mode available. Based off the information you have provided you may be experiencing an issue with your timer or knob. I would suggest performing a factory reset on your dishwasher and you can do that by flipping the breaker off for at least ten minutes. Since it could be an issue with either electrical components you may need to seek guidance from a professional technician. I hope this information is helpful to you. -Matt
Apr 27, 2016 | Frigidaire 24 in. FDB126RB Built-in...
My whirlpool cabrio washer won't start but doesn't show an error code
How old is the machine if its and older modle the switch probably just went bad which is an inexpensive and easy fix
Dec 27, 2014 | Whirlpool Washing Machines
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
F3 error fault code
Nov 14, 2010 | Whirlpool 33 in. ADP6830 Free-Standing...
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
What does error code F3 means?
error code f3 shows that there is a problem in the heating circuit of the dish washer. you may need to access the Heater or relay on the control board for any defect also check the wiring
Apr 05, 2010 | Whirlpool 24 in. ADP5962 Free-standing...
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a whirlpool sixth sense dishwasher and
F3 error fault code
Aug 25, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
1,862 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
