Question about Cuisinart BFP-703 SmartPower Work Top Blender
Burnt out motor?
It jammed for a moment while crushing ice and now the lights come on but motor won't turn. Burt out? Fusible link? Fuse?
  • 11,896 Answers
The motor most likely burnt out. Happened to mine to.
Posted on Jul 02, 2009
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
Blender is spinning but not crushing ice and smoke coming out of bottom
Smoke sounds like the motor is burned out, or possibly just overworked. You could let it rest for 15 minutes and try again, but be careful, as the insulation on the wires could have melted.
Smoke in appliances is usually a bad sign!
Nov 17, 2014 | Blenders
GNC On the Go Blender
these have a fusible link in line with motor normally
you will need a multi meter
Aug 17, 2014 | GNC On-The-Go-Blender - Red 6 Piece Set
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Need instructions on how to use.
Go to GE website or any brand and look for user manuals. They have recipes and instructions. And it's all free information! Try these:
http://www.gehousewares.com/products/840079000_1068232922783.pdf
http://www.gehousewares.com/Product_Search.aspx then select FOOD PREP, then BLENDER, then SEARCH and there will be about 10 user manuals you can browse for instructions and recipes. Instructions for blenders are pretty much the same. Don't put too much in the jar, no more than 3/4 full - I keep mine to 1/2 full. DOn't make recipe too thick or you will stress the motor - add water, milk or other liquid. Don't do ice cubes unless your machine is made for ice crushing. Good luck!
Jun 13, 2009 | Blenders
Help me revive my dead Oster blender
Check the motor brushes. They may be worn out. Also, since the 1980s, many electric motors have a thermal fuse in them. This unit "blows" when it gets to a certain temperature.
This fuse looks like a 22-caliber bullet and its pointed end is usually colored. If you have an ohmmeter or continuity checker, see if current will pass through the fuse. If not, you can try to replace it. Most times, the fuse is attached with crimp-on connectors. Replacements can be soldered in, if you put a clip-on heat sink between the fuse body and the soldering iron.
Mar 09, 2008 | Oster 6854 14 Speed Blender
Cuisinart BFP-703 SmartPower Work Top Blender Logo
615 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
