Question about Samsung DLP HL-P5663W 56" TV
I have a samsung 50" DLP tv and it starts having v-hold issues when certain bright colors are being projected.....what can I do to remediate or am I screwed
  • 643 Answers
Sounds like your color wheel is going bad. usually the fix is pretty inexpensive. there isnt a vertical hold on those type of sets.
Posted on Jul 02, 2009
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
I HAVE A 50 HLM507W SAMSUNG TV WILL WORK FINE FOR 30 MIN THEN COLOR WILL GO GREEN AND BLUE AND STREEKS OF WHITE LIKE LIGHTING
When these colors show up if you can still see the on screen menus with no issues then more than not your digital board is bad. If they are not visible and are distorted as well then the DMD board is bad. Either way both are technician replacement items as the set requires alignment after either one is replaced.
Dec 04, 2009 | Samsung HLM507W 50" Rear Projection HDTV
I have samsung DLP TV HL-R5087W with pink/green discoloration
NO ,its not the Lamp it is your Light Engine. Call UED for price of rebuilt one 1-800-648-6657.
Sep 24, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
I have a problem with samsung sp 50 l7h a 50 inch dlp tv
I can see you have a Samsung TV, well the issue seems to be your ballast which doesn't have enough voltage to keep on with your lamp. This is why you keep losing the picture every certain amount of minutes. The thing with Samsung Tv's is that they have issues with the ballast and the color wheel, they tend to go bad pretty fast.
Jul 27, 2009 | Samsung Televison & Video
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Samsung 50' DLP Tv. Is it a lamp?
there is a lamp door in the back for end users open it up and check it out, could be the color wheel exploded also
Jul 08, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
167 people viewed this question
Jerry Greenberg
Jerry Greenberg
