Question about Canon PIXMA MP600 all-In-One InkJet Printer
What does error code 6a00 mean - Canon PIXMA MP600 all-In-One InkJet Printer
  • 453 Answers
This error code means a mechanical error.
I managed to get this piece of information from a forum
You may or may not find this usefull.
I thnk the 6A00 is a mechanism jam code.
Regarding Error code 6A00. I have a Canon Pixma iP5000. I got that code. No easy answers on the net so I took it apart myself. The covers are all snap locked on. It was a bit painful but I got the side and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaners squeegie on the printhead. This mechanism seemed to be stuck at its full extention rather than being back at home base. Every time I turned it on and off I could see it tried to move but seemed to be stuck. I gave it a little assistance and that released it. I think it had become glugged up with drying ink and that had acted like a glue holding it out at full extension. The mechanism that drives the sliding squeegie relies on a spring
for it to return. The spring wasn't strong enough to over come the gluey ink and so the whole thing jammed up which is probably what the code means - jammed mechanism. If you are going to try it. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. You'll release one part only to find it hooked up at the next snap lock. Some are hidden under or on opening covers so keep looking. The base seems to be securly attached to the workings so dont try and get it off. Just top and sides. Ink is water based so a damp rag is all you need to clean. If youre not technically minded dont bother.
Dave
I got this from http://www.fixyourownprinter.com/forums/inkjet/37440
Posted on Jul 02, 2009
  • 11,896 Answers
There is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local Canon Dealer will know for sure!
  • 421 Answers
SOURCE: Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Posted on Nov 15, 2008
Webcauldron
SOURCE: error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Posted on Mar 02, 2009
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
  • 3422 Answers
SOURCE: Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Posted on Aug 13, 2009
komguy
  • 2306 Answers
SOURCE: Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Posted on Dec 04, 2009
Error code 6a00
Error code 6A00 means an error occurred in the AP motor during purging operation. You will need to replace the sheet feed unit (part no. QM2-2916), logic board assy (part no.QM2-3078), purge unit (part no. QM2-2925).
Feb 12, 2011 | Canon Pixma MP500 All-In-One InkJet...
I have a PIXMA MP500 printer. It is showing an error code 6A00. Can't find any reference to this in the User's Guide. What does it mean; what should I do?
Try first unplugging the printer power cord for ten minutes, ansd see if this correct the error, if not we will proceed troubleshooting.
Sep 09, 2008 | Office Equipment & Supplies
Printer has error code 6A00. What does that mean?
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Purge unit (QM2-2925).
Jan 20, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Canon pixma mp800 error code 6A00
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My MP830 has an error code of 6A00. The assembly
6A00 means the purge assembly is jammed or worn out. Part number QM2-3032-000 around
$30.00. It's the cleaning assembly on the right where the printhead parks when shut down.
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 01, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
171 people viewed this question
old marine
old marine
