Question about Carrier 38CKC036 Air Conditioner
Have carrier heat pump that buzzes
Last year I repleaced the swollen capacitor. This year same issue but the capacitor is not swollen. Any ideas?
  • chrischipps Jul 02, 2009
    it will buzz continue to buzz. Fan will move freely when pushed.
  • 1,056 Answers
What exactly does it do? If it buzz and don't turn a starting capacitor will not help, this is an indiction of a shorted motor.
Posted on Jul 02, 2009
  • Ronado Panaligan
    Ronado Panaligan Jul 03, 2009
    yup you decribed it perfectly, motor is bad. they cost about 50 bucks at an ac supply.
    Problem Solver:
  • 16 Answers
Check your contactor they will buzz when they go bad and make sure you have 220 volts at contactor.
Posted on Jul 07, 2009
Carrier throught the wall a/c and heater unit. When you turn it on, the compressor buzzes for a few seconds and then goes off. The heater nor the fan motor comes on either. Any ideas on where to start?
Start by making sure its getting the right voltage (line and load side of the contactor) then check the capacitor/s. Let me know what you find so I can go further if I need to.
Aug 23, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My heat pump fan will not turn
First, with the unit not running, check to make sure the fan spins freely. Next check the capacitor. You can do that with a multimeter or look at it and if it looks swollen then it is most likely bad. Replace it with one of the same rating. If the capacitor is good then use an ohmmeter to check the fan motor windings. Also check the condition of your contactor and make sure the ciruit breakers are closed and the fuses are good. The breakers should be off before you check the capacitor, fan motor, and contactor.
Jun 04, 2010 | Amana Heating & Cooling
Condencing fan is not spinning and very hot to the touch, the compressor is making a buzzing noise.
Check the capacitor. You can use a multimeter to do that. Also if it looks swollen then it probably needs to be replaced. Some units have just 1 that controls the fan and compressor and just 1 side can go bad.
May 23, 2010 | Carrier 38CKC060 Air Conditioner
The outside unit buzzes and will not turn on
You have an electrical problem I'd call for service and if has not been cleaned in a while has it cleaned for best performance. Tom
Jun 28, 2009 | Carrier 38CKC036 Air Conditioner
A/C not working - just blowing uncooled air
this is a 3 ton unit it still has parts warranty on it if you look inside the fan area of out door unit the reversing valve has 3 copper lines on one side and 1 on the other fyi when giving call for cooling out door fan running? if no check for fuses in disconnect at unit or breaker off in panel remove panel where power comes to unit pull disconnect look at capacitor silver thing with wires on top if swollen on top bad hope this helps some
Jun 04, 2009 | Goodman CLQ36AR49 Air Conditioner
N15235 win fast motherboard
The main cause behind this problem is :-
1) RAM JAM
2) HDD is taking extra power from SMPS
3) Motherboard faulty Capacitors / ICs
Try following :0-
step 1) Remove CMOS Battery (3V battery) + RAM
and now try to check whether Fan shows same symptoms or not
Step 2) if results of above step is fail then try to remove HDD powersuppy + CD/DVD power supply + Floppy Power supply (in short provide power to only motherboard) and now start the system.
If the result are same
3) then look for any swollen capacitors on motherboard, if they are then you need to replace them.
4) If no capacitor is swollen then check for every bigger IC on motherboard for whether it got excessive heated or not. If yes then you need to do serious operations on your motherboard .
Please not here i have used the word EXCESSIVE HEATED. and noth the normal heated
May 29, 2008 | Computers & Internet
Polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Jan 15, 2008 | Polaroid FLM-3232 Television
Carrier 38CKC036 Air Conditioner Logo
189 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
