Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Icemaker not working after installing new filter
Icemaker has stopped working with a new filter installed-- even though the filter light is showing it is correctly installed working
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Posted on Jul 05, 2009
PFSF5RKZC Icemaker stopped making ice.
Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
Apr 03, 2014 | GE Refrigerators
When hd is plugged in, it installs device and drivers automatically. it never shows up under my computer but in the taskbar it shows safely remove hardware. power light shows orange but harddrive light...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Nov 14, 2010 | Seagate (9W2063500) 120 GB Hard Drive
Code er if
The Appliance Servicer should have checked the unit first before trying to install any part.
Apr 08, 2010 | LG LFX25960 Bottom Freezer French Door...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
Ge profile evaporation fan installation. Where is it located?
It's located in the freezer compartment . May have to remove all panels , including the icemaker , to install it . If the fan isn't working though , the problem is probably the main control board , located behind an 8 " X 10" panel , on the back of the refrig . Usually , a resistor burns out and the freezer fan stops working .
Sep 19, 2009 | GE Refrigerators
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Nov 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
425 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
