Question about Coleman Air Tools & Compressors
I have Black max Series model #bp0501813 5.0 h.P Changed pressure to 40 pd. because of a small paint job now I have tried to back to normal pressure 135. The knob that controls the pressure must be bad. Can you help?
  • 2,418 Answers
Some of these knobs have to pull out to readjust, eather pull out or push in. most are a pull out and turn, then push in to lock it there. Try that.
Posted on Jul 02, 2009
How best to prepare painting over oil based varnish
The best bet is to leave the oil poly on the treads clean it up and refinish it .
However if you need to paint for what ever reason I would recomand grinding back to wood its a lot of work pine or oak treads .
But the problem is stairs get a lot of LBS. per sq/in .In a small area of the tread and depeneding on how high of a traffic area it is nothing will stick to oil poly or varnish.
Strip them and go with an epoxy system .
And by the way I have running comerical paint jobs for 40 years
Mar 12, 2015 | Air Tools & Compressors
How much should I thin paint for pneumatc sprayer?
you did not mention what paint, you did not mention what sprayer.
remember, if you use solvent - opacity of the paint is sacrified, tints are less visible, metallic require more clear coverage.
for water based paints - except airbrush, usually no thinning is required, but you need to first stir it well (at least 3min on manual or 1min 30sec if mechanical stirer is used) strain it, i am using old stockings for that purpose in single layer, works very well for me and if nozzle is above 1.4mm up to 2.8mm there is no problem whatsoever. if this is splatter paint (nozzle 4.5mm or greater) do not even think about thinning it...
for acrylic - if nozzle is between 0.8mm and 2.8mm, procedure as above and you need to add specific thinner, usually up to 20% albeit in some cases up to 40% per volume) so paint will be about like ight cooking oil - water.
for oil paints and enamels - solvent should be not more than 20%, albeit you can increase it up to 40% in rare circumstances, if you are using hvlp gun, you can, if you yousing hp gun - no! it will disperse too much.
for two packs and urethanes - not more than 20% better keep between 5% and 10%
for latex - in rare circumstances you are allowed to use very, VERY specific solvent, and ususally not more than 10%, nozzle usually is 8mm or greater in these paints.
Oct 19, 2014 | Air Tools & Compressors
On my 1996 ss impala what low side pressure should I see on the a/c with the system running
It all depends on the outside (ambient) air temperature. Your A/C low pressure switch is designed to turn the compressor off at 24 Psi. and turn it back on at 45 Psi. Most systems will normally run at between 25 and 40 Psi when the system is running on HIGH blower and "MAX" or "RECIRCULATE". A system that is fully charged may run at 25 Psi when the ambient temperature is 75 Deg. (F) and may run at 40 Psi when the ambient temperature is at 90 Deg. (F). (it can be even higher if ambient temperatures are higher than 90 Degrees.)
To properly diagnose a malfunctioning A/C system, the HIGH side pressure must also be checked. Restrictions in the system can make the low side pressure look normal while the high side pressure is high enough to blow hoses apart. (400+ Psi.)
Sep 04, 2011 | 1996 Chevrolet Impala SS
I have a 7 series samsung and it keeps going on and off by itself. I tried different plugs but nothing changes
The main tv processor might have some garbage in it, do to a small power surge. If you unplug the TV from the wall for 40 min. that should reset it back to normal.
Nov 11, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a 2002 Wranglet 4.0L. lately I've noticed the oil pressure gauge running near max. The users manual says normal pressure is between 45-65. My oil level is normal and I don't notice any leaks. The...
oil gets thicker as it gets older,so pressure increases,try puting in sae10/40 simi synthetic with a new filter...the pressure 45-65 is an average pressure lower road speed lower pressure/higher means higher.....
Sep 11, 2010 | 2002 Jeep Wrangler
Intermittent problem oil pressure dropping off
the oil pressure relief valve may be sticking causing a fluxuating oil pressure .this valve allows acess oil to flow back to sump hope this helps!
Apr 11, 2010 | 1997 Jaguar XJ6
Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Feb 09, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Work problem
Here is the answer:
Daisy did 2/5ths or %40 of the barn in those two days as she can do the whole lot in 5 days she did 2/5ths or %40 in 2 days so thats %40 of the barn done.
Didith did 2/8ths or %25 of the barn in those two days,
so the amount of barn painted in the first two days is: 1/4 + 2/5 which equals %65 of the barn complete in the first two days. so there is %35 of the barn left to paint and only Daisy (who can paint %20 of the barn in one day)
so to figure out how many days it takes Daisy to paint %35 of the barn this is what to do:
%20 = 1day %35 - %20 = %15 5x5x5x5 = 20 5x5x5 = 15 therefore it takes Daisy 1/4 of a day to paint %5 of the barn therefore it takes Daisy 3/4 of a day to paint %15 of the barn (i hope you are following me here!) 1 + 3/4 = one and three quarters of a day
Therefore it took Daisy one and three quarter days to paint the remaining %35 of the barn.
So it took Days one and three quarter days to finish the job after Didith left.
Hope this is helpful
Emmanuel
Sep 17, 2008 | Computers & Internet
Air Tools & Compressors Logo
353 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
