Question about Elite Sl 3000 Ul Sliding Gate Operator
When should I replace battery for Elite Robo-slide gate opener.
When should I replace battery in electric gate opener? Gate is not not closing all the way. Beeping indicator shows low battery.
  • 52 Answers
Sounds like its time to replace now!
Posted on Jul 02, 2009
How do I sync a Chamberlain remote 371LM to a Chamberlain gate opener Elite Robo Slide?
There are two possibilities. The first and easiest is a sync button on both. Much like a Wii remote, you might be able to find a sync button (most likely small and indented) to have both devices search each other out. The other possibility is registering the remote to the gate. You may have to call in and have help, including giving find and giving the remotes code.
Elisa Jed ' http://abfabrications.com.au/fences-gates
Jul 19, 2014 | Home Security
Elite slider gate opener sporatically stops partially closed
first guess a bad electric motor
second guess to much resistance between the gate and the tracks try manually moving the gate does it get stuck at some point
3rd tighten any and all loose bolts throughout the system
Feb 04, 2018 | Home Security
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
I have an elite robo swing r900 gate opener. gate door's are not closing, battery keeps beeping and it shows low battery
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Nov 09, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Dec 19, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Sliding gate will not close
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl 3000 Ul Sliding Gate Operator Logo
960 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
