LCD image
SOURCE: trouble getting video out to work on canon eos rebel xt
have u changed the PAL or NTSC seting ? u can find it in video system in the last seting menu
SOURCE: wrong number of pictures left
Try the freeware program "VAIOSoft Recovery Manager" listed on the following webpage:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
SOURCE: Image blacked out on LCD and can not see image in view finder
Try this, it may or may not work. Insert the Video cable plug in and out of its slot a few times. The cable when inserted turns the screen off. But sometimes corrosion can build up on the internal plug switch, also causing the screen to turn off. Inserting and removing the cable a few times can sometimes knowck off this corrosion.
SOURCE: lcd screen is not showing
Was the camera dropped or hit hard? I had to replace the display screen on my Canon Power Shot A95 because I had dropped it. I purchased a new LCD screen from a company on eBay. It was relatively inexpensive but you do need some experience with small screws and connectors to do it your self. One last thought, try new batteries. I am sure you have but I forget the obvious sometimes.
Hope this helps!
