Question about JBL GTO1204D 12" 1200 Watts Subwoofer Car Speaker
Ripped center part
Hi i just got a 12'' JbL sub from a friend. the problem i have is that the middle little circle piece had ripped from the main part of the cone in a triangle shape. It is still there but just flaps around when it is being used. is there a way i can glue it or do i have to take it to a shop, what can i do?
  • Jay
    Jay Jul 02, 2009
    What would be best to use. I heard nail hardener, modeling glue, silicone and rubber cement.
  • 1,056 Answers
You can glue it as long as it is still fuctioning, of course let it dry completely before using it again.
Posted on Jul 02, 2009
  • Ronado Panaligan
    Ronado Panaligan Jul 03, 2009
    whatever the material is use the one thats recomended for that material. It speakers once operating dont really excert a lot of load on that part. just make sure it is dried completely.
The rubber mount on the bottom/front anti vibration motor mount is ripped into 2 pieces, what is the replacement code?
    Installing anti-vibration mounts on the Husqvarna 288xp ...
    ? 17:26
    https://www.youtube.com/watch?v=Rn_9k9sutqk
    Sep 12, 2012 - Uploaded by Mark Hawes
    Installing anti-vibration mounts on the Husqvarna 288xp ....Engine Rebuild On Husqvarna 55 & 51 Chainsaw ... images for chainsaw front anti vibration motor mount
Oct 31, 2015 | Garden
Dust bag ripped, now wont turn on
dust bag not the problem so take into guarantee vacuum and sewing center and they will clean it out completely and get it fixed and running like new at as little cost as posible
Mar 25, 2014 | Nilfisk Vacuums
Bobins
To "wind" a bobbin you can:
1 - Look in your book
2 - Google : how to thread a bobbin on a kenmore "12 stitch"
3 - Youtube https://www.youtube.com/watch?v=Fe11QQubfqw
4 - Ask a friend
To "make a bobin"
1 - Get some 0.5mm stainless steel
2 - Cut two 19mm circles out of the 0.5mm steel
3 - Drill a 6mm hole in the center of each circle
4 - Solder (silver solder work the best) the 2 circles together with a 6mm round by 9mm tall cylinder in between the two 19mm circular pieces.
Mar 13, 2014 | Husqvarna Viking 1
12 inch sub(JBL) in box with a 500 watt pioneer amp, sounds good with some types of base. would you cut a port hole in speaker box?
riverray1969 it would help if I knew the exact model number of that JBL sub you are referring to. With that info I can provide exact specs.
Basically, you need to build/modify an sub enclosure that is suited for the sub, the music you mainly play, and vehicle tuning. Generally, sealed enclosures will provide tighter bass response and get decently loud. Some would argue that it will give you greater sound quality. A ported enclosure will give you a louder more booming sound. That depends also on where the port is tuned (ex. 32 hz, 36 hz, etc ). You need to make sure that the enclosure meets the sub's airspace requirement as well. A customized well made enclosure is just as important as the sub you put in it.
Oct 16, 2012 | JBL P-1020D Car Subwoofer
My pull cord ripped, and the spring came out how
I hope you have strong hands. Start by holding the inside end of the spring in one hand, then carefully wind the spring back into a circle tightly until you get to the other end. The finished diameter of the spring must be a little smaller than the area it goes back into. Put it back in, then replace the pulley like it was when you disassembled it.
Sep 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Broken transponder,wires ripped out.car wont start
Dealer, due to the ignition system complexity and the
possibility of a anti theft device involved.
Jun 18, 2010 | 2000 Acura Integra
My subs sound choppy
Sounds like your sub is "clipping". Clipping is when your speaker is trying to pull more power than the power supply. (head unit, amp) If it sounds good at a low volume and choppy at high volume, supply it with more power. Bigger amp. If it sounds choppy all the time, push gently on the middle of the speaker. It should go back and forth smoothly. If it feels rough, you have blown the coil. Replacing the speaker is the fix for that.
Apr 14, 2010 | Sony Xplode P5 Turbo Subwoofers Car...
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Thermal ribbons broke in dye sub printer
hi,
by ripped, do you mean that the ribbons have come off the hinges or are they torn?
if they are torn, any small cracks or torn edges will not harm much. but if the ribbon is sliced to pieces, they have to be replaced, as you cannot work with torn ribbon. here is a link to the manual with which you can replace the ribbons.
cheers
Jul 26, 2009 | Kodak PROFESSIONAL 9810 Thermal Photo...
I have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
May 18, 2009 | MTX RT12X2-200 Car Speaker
Car Audio & Video Logo
64 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Steve Sweetleaf
Steve Sweetleaf
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
