A
Anonymous Posted on Sep 06, 2014
What is the magnafication factor of the 18-1561?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Office Equip... Master 102,366 Answers
  • Posted on Sep 06, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443354
Points
622693
Are you asking about the Bushnell telescope? The maximum magnification is 150x.
1helpful
2answers
What is least common factor
Normally, we look for the greatest common factor and the least common multiple.
To find the least common factor, we have to factor both numbers and see what the least common factor is. However, we know the one set of factors for every number is itself and one. For example, 56 and 49.
The factors of 56 are 1, 2, 4, 7, 8, 14, 28 and 56.
The factors of 49 are 1, 7, 49.
What is the least common factor of both numbers? 1
So the least common factor of any two numbers is 1.
Any questions, let me know.
Good luck,
Paul
1helpful
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Is there an online User Manual that can be downloaded, as the one included in the package is difficult to read (small print).
Hi, I would like to say (put some glasses on) but you can get a magnafing glass or get someone else to read it for you. But yes, there maybe a PDF version out there. You will have to send us the brand and model #.
What is a bad solder connections
it will look dull and under magnafication it will have a ring or crack aroiund it also you can move the componet and you should see the lead move were it is soldered to the circuite board
Picture drop out when watching regular TV, sound if okay
that chassis has a lot of poor solder areas that need to be gone over with good solder and magnafication and stong light
ron
k24674
ADMIN Andrew
ADMIN Andrew
