Question about Datamax DMX I-4206 Printer
Printhead leaves impressions but no print - Datamax DMX I-4206 Printer
  • 3 Answers
Datamax printers DO NOT use Ink Cartridges. They use ribbon wound on a core.
Posted on Jan 19, 2010
  • 52 Answers
Sounds like you've run out of ink? If not then the ink has become dry and clogged the head.
Try using a alcohol solution (white spirit or a strong liquor like vodka will suffice) with a piece of paper towel to clean the head of the ink cartridge, then try printing a few times until it works well.
Otherwise, sounds like the cartridge needs repalcement.
Posted on Jul 02, 2009
Not printing full card
it's possible that some elements from the printhead are damage, you will have to replace the printhead. Try to print the demo card, if still happen, possible printhead.
Mar 04, 2014 | Zebra P330i Thermal Card Printer
Printing stripes
You may have dried ink in the printhead. You can remove the printhead and try cleaning it at home in hot soapy water, rinse, then leaving it to dry thoroughly. Certainly won't leave you any worse off than you are now, and may well do the trick.
Jan 28, 2014 | Kodak HERO 7.1 PRINTER
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
Officejet K5400 Won't print yellow
Hi David,
Turn Off Your Printer Remove K&Y Printhead from your printer. Put the Printhead in the bowl in the same Position As in the Printer And Pour Little hot water in the bowl till the printhead is half dipped in the Water. Leave in for 15-20 Min. after that Clean the Printhead with clean clothes.. Must Ensure that no Water is in the Circuit of Printhead. leave the printhead for 30 min. After that put Back in the Printer. You will Get the Better result than ever BUT PLease Donnot use clean Printhead Utility immediately after this process use after the Day. If it Doesnot Work Then Clean the Printhead in Hot Water Several Times.. Do not Remove Printheads Regularly From Your Printer..
I Have the Same Printer And Suffered Same Problem A Month Ago with Yellow Colour...
Regards,
Sean
Aug 10, 2012 | HP Officejet Pro K5400 All-In-One InkJet...
When printing, print is has irregular & has white streaks through letters. Have tried "Print Head Cleaning" & "Print Head Deep Cleaning" several times and now printer won't...
you can flush the printhead on running water.
and have a mixture of ammonia and water solution. Soak the printhead and leave it overnight. This will unclogged residue in the printhead.
it will work again as good as new.
Jan 18, 2011 | Canon PIXMA iP3500 Printer
After numerous cleaning cycles the nozzles on my Pixma MP970 still show streaked patterns when printing the nozzle check. This printer has always has had poor print quality mainly black text. We got it as...
It will need a new printhead, QY6-0062-000, around $80.00. Leaving it sit and not printing just makes the problem worse, as more nozzles on the printhead get plugged. You get 90 day warranty with refurbished units and if it started out crappy you should have had a shop look at it, that model can print super photos! A new printhead will bring it back to life.
Dec 24, 2009 | Canon PIXMA MP970 InkJet Printer
White lines 1/2" when printing
Sounds like you may have damaged the printhead or the printhead connections.
I'd recommend removing the cartridges and then the printhead and check for any obvious signs of damage or soiling on the base of the printhead and/or on the back of the printhead. There's also a series of contact plates in the carriage unit (the bit the printhead and cartridges sit in)... These pins can become damaged.
Finally... if the process of removing the jam involved a lot of pulling and shoving you may have damaged the feed mechanism... Hard to know without seeing it so worth checking that some paper and/or ink hasn't soiled any of the calibration strips and is causing the printer to get "lost".
Appreciate the above is a bit technical but start with the printhead and work your way carefully through, looking for anything that might seem out of place or "odd".
Hope that helps.
Martin
Sep 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP K5400: Y and B color are failing printing
Apr 29, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Printing shifting backward
You probably need to clean the sensors, turn the printer off open the side cover, lift the printhead and you'll see the sensors. Clean them with a damp cotton bud.
May 16, 2008 | Zebra Z4Mplus Label Printer
Datamax DMX I-4206 Printer Logo
127 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
