A/c on ford escort lx has stopped working. The pully and clutch to compressor appear to be in working order. What possibly could be the problem because its not blowing at all
  • 1,056 Answers
If it is not blowing at all then it is the blower fan not working. Check the fuse first before anything else. If it is not the fuse then most like it is the fan that has a worn out brush inside.
Posted on Jul 02, 2009
How to turn off air compressor on 1999 ford expedition
  • Under the hood in the relay panel will be a relay for the compressor. When you locate the relay box look on the underside of the lid for the legend (layout) of the relays. Pulling that relay will stop the compressor from turning on.
  • You can also just unhook the connector on the compressor and secure it to stop the compressor from turning on.
  • If you need the compressor clutch to not turn at all, like if the bearings are bad, then you need to buy a smaller belt to bypass the compressor all together.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 19, 2011 | 1999 Ford Expedition
Hello, i have a 98 ford escort lx, no power to a/c compressor, replaced high and low pressure switches,checked to compressor, replaced orfice tube, put freon, checked pressure (but its high), checked a/c...
There is a red wire going to the AC clutch, if you apply direct 12volts will it engage? If so, the constant control relay module (CCRM) could be defective. Hope this helps.
Jul 04, 2011 | 1998 Ford Escort
How to remove ac clutch coil on 2002 ford escort
You need special tools to remove the clutch unit of the AC Compressor, i would let a shop do it there is proper spacing when installing a new clutch that needs to be made in order for it to work
Aug 24, 2010 | 2005 Ford E-Series
Where is the clutch hydraulic reservoir on a 1993 ford escort lx?
The clutch and brake system use the same reservoir, there is a hose coming out from the side of the reservoir that goes over to the clutch master cylinder. Sometimes the brake fluid level goes low as brake pads wear and lowers the fluid level too low to work the clutch. Hope this helps, let me know.
May 19, 2010 | 1994 Ford Escort
I have a 1993 ford excort lx 1.3 engine the bottom pullie stops pulling do i need a new water pump.and how do i put it on
If this pulley is not turning and this is the center bottom pulley your motor is locked up.Bottom pulley in the middle is your crankshaft.This being if the motor does not run or turn over.I this is not the case, I can give you details on how to do water pump.
Dec 01, 2009 | 1993 Ford Escort 4 Door
There is a burning smell under the hood smells like its coming from a belt what could it be? Ford escort se
Old belt, belt misalignment, belt tension incorrect, failing belt tensioner, or bad condenser or alternator not turning correctly.
Nov 16, 2009 | 2002 Ford Escort
I need to replace my 1993 ford escort GT's slave cylinder
just unbolt it and undo the pipe then refit the new one the sme way in reverse order
Aug 11, 2009 | 1993 Ford Escort 4 Door
Screching noise when i turn on AC
sounds like front bearing on compressor. clutch works on magnetic pull in principle so screech is probably bearing and not clutch assembly.
May 09, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
