Question about LG LRSC-26922 Side by Side Refrigerator
I am unable to pry up the faceplate.
I am able to get a screwdriver under the corners, but it will not pry up. I am afraid I am going to snap or break the faceplace. Help!!!
    President:
  • 1,136 Answers
Hi, If you are trying to get the plate off of the dispenser, there might be 2 slots under the bottom front edge that you can insert the screw driver in and pry. It will take a little force. Also look under the fron edge and make sure there a small screw holding it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
Just having done this, we used a couple of stiff bladed putty knives. When the popping noises start, you're good to go. It's really on tight.
When you get the plate off, remember to write down where each little electronic connection goes (there are 3 on ours). ALSO, the funnel does not get snapped in until the frame is installed and everything is back on.
Posted on Jul 15, 2009
Is it possible to disassemble the BN59-00851A Remote? I see only one screw under the batteries, and removed that, but the cover will not come apart. There must be some sort of screw or snap still holding...
I actually opened it!!!!!! You will need something super thin yet strong to get the
faceplate off pry upwards where the tabs are. I used a small screwdriver and chewed up the sides. hope you have a better way. after it is off it is easy to disassemble the rest. When putting it back on make sure the battery terminals get into their slots and just snap back on. good luck!9_29_2011_2_09_04_am.jpg9_29_2011_2_09_18_am.jpg9_29_2011_2_09_27_am.jpg
Dec 22, 2010 | Samsung BN59-00851A Remote Control
How do I remove drivers door panel to get at power window motor?
Found this while looking to replace speakers:
DOOR WITH POWER LOCKS AND WINDOWS First remove the triangle piece in the top corner of the panel (piece closest to the outside mirror). This can be done with a plain screwdriver and just a little
prying and it will snap off. Second, remove the door lock inset, same screwdriver, little prying
and it snaps out. Next remove the cover inside the door handle, same screwdriver, pry and snaps out
(turn it upside down and slide it off. Now you will need to remove the cover that holds the window
and door lock buttons, same screwdriver and pry upwards just a little and should pop off. Ok now you
will need a small socket to take out three screws. One is inside the button panel you just took off,
the second is inside corner of the door arm, (the handle you grab to shut the door, look under it,,
see it yet, yeah thats it). The last screw in on the very bottom of the whole door panel, you will
have to get on your hands and knees to see this one Now would be a good time to remove the door light on the corner, same screwdriver, pry from the red lens side outward, once out, remove the wire termial. Ok.... now grab the under side of the panel where that last screw was and lift upwards, apply a little more pressure till the panel pops upward about an inch. Now your door panel is loose, you can lift it off a little but you will need to remove the wire from the tweeter. The termial has a locking tab you need to press down to remove it.
May 21, 2010 | 1999 Chevrolet Silverado 1500
Replacing bronken mirrorbody w/new one, have mirror on long cable
found this while looking to replace speakers:
have to get on your hands and knees to see this one. Now would be a good time to remove the door light on the corner, same screwdriver, pry from the red lens side outward, once out, remove the wire termial. Ok.... now grab the under side of the panel where that last screw was and lift upwards, apply a little more pressure till the panel pops upward about an inch. Now your door panel is loose, you can lift it off a little but you will need to remove the wire from the tweeter. The termial has a locking tab you need to press down to remove it.
May 15, 2010 | 1999 Chevrolet Silverado 1500
How do i remove the inside door panel on drivers side
on silverados:
have to get on your hands and knees to see this one (yeah thats it right there). Now would be a good
Jan 19, 2010 | 1999 Chevrolet Silverado 1500
The water dispenser is displaced on my Whirlpool refrigerator ED5RHAX NO00. I am trying to remove the face plate but am afraid to crack it. Any suggestions?
I eventually managed to remove the faceplate, using a screwdriver in the bottom slots of the faceplate and prying it loose, sliding it up to remove it from the slots at the top of the faceplate.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
HOW DO I REMOVE THE PASSENGER SIDE DOOR PANEL TO FIX MY ELECTRIC WIDOW PROBLEM THANKS DON
DOOR WITH POWER LOCKS AND WINDOWS> First remove the triangle piece in the top corner of the panel (piece closest to the outside mirror). This can be done with a plain screwdriver and just a little prying and it will snap off. Second, remove the door lock inset, same screwdriver, little prying and it snaps out. Next remove the cover inside the door handle, same screwdriver, pry and snaps out (turn it upside down and slide it off. Now you will need to remove the cover that holds the window and door lock buttons, same screwdriver and pry upwards just a little and should pop off. Ok now you will need a small socket to take out three screws. One is inside the button panel you just took off, the second is inside corner of the door arm, (the handle you grab to shut the door, look under it,, see it yet, yeah thats it). The last screw in on the very bottom of the whole door panel, you will have to get on your hands and knees to see this one (yeah thats it right there). Now would be a good time to remove the door light on the corner, same screwdriver, pry from the red lens side outward, once out, remove the wire termial. Ok.... now grab the under side of the panel where that last screw was and lift upwards, apply a little more pressure till the panel pops upward about an inch. Now your door panel is loose, you can lift it off a little but you will need to remove the wire from the tweeter. The termial has a locking tab you need to press down to remove it.
Jul 29, 2008 | 2000 Chevrolet Silverado 1500
How to remove center console faceplate?
after looking around the edges for small screws gently start prying around the edges at the corners first. the best option is to have your new cover plate in hand and u will see exactly where the snap clips are at and then you can "Gently" pry at those spots with a flat screwdriver to pop it off with
Jul 19, 2008 | 2005 Chevrolet Equinox
Driver side window lifter switch
Use a plastic wedge and pry it up gently, if it means getting two and going at it from two corners then do that.
Jun 20, 2008 | 2001 BMW 330
Putting on faceplate for samsung t319
hi you best bet is go to a repair mobile shop if are in doubt to try this .
you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
riz.
Aug 23, 2007 | Nokia 6288 Cellular Phone
LG LRSC-26922 Side by Side Refrigerator Logo
184 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
