Question about Tomtom GO 510 GPS Receiver
RED X ON WHEN STARTING UP LIKE THE MEMORY CARD . WANT GO ANY FUTHER
I av this problem can any 1 help
Posted on Jul 19, 2009
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Oil in my radiator
is it red or black? If red it is ****** fluid, replace ther radiator, bad coolant line in the rad.. If black, motor oil. Most likely blown head gasket, and or cracked block Check head gasket first, then start digging futher in.
Aug 11, 2012 | 2001 Jeep Grand Cherokee
I currently have samsung camer with over 300 photos on there. Last night i changed the settings so the time and date would appear on any futher pictures taken. However it has seemed to clear my camera and...
You can recover lost photos from memory card of your digital camera with this
1. Do not save any new photos into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Jul 31, 2011 | Samsung L200 Digital Camera
When I start the camera, it says in red "this card
hi there...
i have once experienced the same as you
try to format it with your laptop/PC, then reformat again using camera option
if still don`t work, i assume the memory card is broken and you`ll need to buy new one
Jan 13, 2011 | Nikon Cameras
I bought my wife an hp Pavilion dv7 for Christmas a little over a year ago. Recently the power cable started to crack right where the cable meets the recepticle that plugs into the laptop. I used some...
try reseating the memory cards in the notebook if the lights come on but no display usually memory cards have been knocked loose.
that is one defect that they have is memory cards come loose if the laptop has been jarred from being in a car getting bounced around in the seat etc.
the memory cards control a portion of the video and if the memory cards lose connection you loose video.
May 15, 2010 | HP Pavilion dv7-1130us laptop
The screen is blank on my Nokia 5800, although the green white and red lights are on.
CHech ur memory card. there can be some viruses or some file corrupted, so scan ur memory card from an updated antivirus & then scan ur memory card by defragment option, it will get u on start/accessories/sytem tools / disk defragment...
after
Scanning & defragmenting insert ur memory card & start the phone.. it will work
S.kumar
Oct 19, 2009 | Nokia 5800 XpressMusic Smartphone
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Sansa fuze
i had the same problem putting on music and what i eneded up doing was coping all my music to a memory stick and using a differnt computer. if you want you could buy a microsd card reader and format the card to put music on it and then just sync the computer to the card and that should work just as good.
Jan 07, 2009 | SanDisk Sansa Fuze MP3 Player
Memory card for tomtom
Did you try reformatting the card?
Jun 09, 2008 | Tomtom ONE GPS Receiver
My HTC S620 stays on second start screen
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM) Remove any memory cards before starting this process.
With OS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Without OS:
Turn the hand-held off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Let us know if you have any other questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Nov 28, 2007 | HTC S620 Smartphone
GPS Logo
180 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
