Question about LG WM1814CW Front Load Washer
The OE Message on my LG Tromm WM1814CW
We have the OE message on. I don't know if the little filters on the back that the manual tells us to check and rinse out are what is refered to as the drain filter or not...I saw it suggested to take the drain filter off and look in behind it, but not sure how to do that...Could someone help? I can't find the user manual and it is discontinued so I can't find the manual.
  • LG Master
  • 2,309 Answers
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Posted on Sep 10, 2017
SOURCE: lg wm1814cw drain error
wm- 12225fd
Posted on Dec 11, 2007
  • 1543 Answers
SOURCE: Can you adjust the water level on the LG Tromm WM1814CW?
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Posted on Apr 07, 2009
  • 6784 Answers
SOURCE: LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Posted on Jul 12, 2009
  • 744 Answers
SOURCE: lg tromm wm2277hs stops when it gets to the rinse
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
Posted on Jul 24, 2009
SOURCE: LG WG3431HW OE Error: Rattling & Not Draining.
water will not drain says oe
Posted on Aug 08, 2009
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Error message oe. and will not spin.
Actually, that is not oe, it is DE, which stands for Drain Error. Check the filter behind the access door on the lower left front of the washer. You should be able to drain the water out using the small hose there first before opening the filter. If there is nothing in the filter, you will have to replace the drain pump motor.
Feb 12, 2011 | LG WM1814CW Front Load Washer
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Jul 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG Tromm WM2277HW OE error message
unit not the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1814CW Front Load Washer Logo
769 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
