Question about Sony KDF-E60A20 60 in. LCD HDTV
Unexpected lamp shutdown
When I turn on my tv, the fans kick in, the video comes up and then the audio turns on. Everything kosher...except the video is about half the normal brightness.
After about 10 seconds the audio and video go blank. The green power LED stays illuminated, then after approx. 15-20 seconds the video and audio come back online.
This is a repeated cycle, over and over.
Any hellp that you can provide would be greatly appreciated.
Re: Unexpected lamp shutdown
I pulled the bulb and noticed dust clogging the vents in the bulb itself i carefully cleaned everything . with an air duster, TV is now staying on with no problems. the overheating did hurt the brightness of the picture so i think this an excellent "get u by until u get a new bulb ". it might be a good idea to preserve the life of the bulb to clean it seasonal to prevent overheating and shutting off.
Posted on Jul 10, 2008
Had the same problem. thanks for the advice. cleaned fine now.
serviceman wanted $200 just to come out and look at it.
3 screws and a can of air... all fixed!
Posted on Apr 15, 2008
    Problem Solver:
  • 5 Answers
Remove the lower front panel by removing the 2 large round screw heads at the lower back corners, one on each side. Remove the retaining screw on the right side of the metal horizontal retaining strip in front of the bulb holder, remove bulb retaining screw in the upper left corner of the bulb holder. Pull the bulb holder out towards you and check for dust build up on the top screen on the bulb casing, if there is an abundance of dust it will restrict the airflow across the face of the bulb which causes it to heat up and turn off. Once the dust has been cleaned your bulb should now work as it should without a problem.
Posted on Mar 13, 2008
I had the same problem.
Replaced the lamp using the instructions in the users manual that came with the TV.
It performs like new.
Posted on Feb 18, 2008
I fixed it by replacing the lamp.
Works like new.
The instructions for replacing the lamp are in the user manual that came with the TV.
Posted on Nov 10, 2007
0 characters
3 Points
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
Jul 24, 2011 | Flat Panel Televisions
I have a samsung dlp. In the past 3 months I have replaced a ballast, lamp and a color wheel. After lamp replacement tv worked great for three weeks. Now TV comes on great but turns off after about two...
It could be that a cooling fan is not operating correctly, allowing the unit to over heat, or the power supply board could be failing. I would remove lower rear cover and see if fan(s) are turning.
Jun 10, 2011 | Flat Panel Televisions
Jvc tv wont come on.
your lamp is burned out-easy and fairly cheap fix. Order a new lamp and install it according to the instuctions sent with the lamp.Dont believe that you need to take it to a service to have it fixed, this should be less than $150 fix-good luck
Feb 07, 2010 | JVC LT-42X579 42 in. LCD TV
Sony KDF-E50A10 50 in. HDTV LCD Television has a ringing sound like a cellular phone whenever the TV is turned on. I have isolated it to near the projector. I have taken out the projector and it still...
There are more than 1 fan in the set; however, the last one to turn off is the lamp fan. The lamp fan keeps your lamp cool and helps extend the life of your projection bulb.
You could either replace the fan, or remove the fan from the set and give it a good cleaning (that's all it might need). However, be aware, fans that go bad in these sets will start to shut down your tv and decrease the life of your lamp. Be on the lookout for intermittent or sudden shutdowns, as those can definitely indicate a bad fan.
Jul 08, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Flat Panel Televisions
DLP TV noise and picture
This is not with the problem of lamp.
Your light engines COLOR wheel is damaged.
Replace Color Wheel.
Good Luck
Dont forget to Rate!!
Nov 05, 2008 | Flat Panel Televisions
Dell W2600
The video drive board may have failed, or the output section of the power supply that drives the video drive board may have failed.
It is also possible and is common on LCD sets, that the backplane lamp supply, and or the backplane lamps have failed.
Turn on the LCD TV set, and shine a flashlight in to the screen at an offset angle. If you can see a bit of the image, you know that everything is working, and it is a backplane illumination problem.
Jerry G.
Apr 09, 2008 | Dell W2600 26 in. LCD Television
Philips TV, Model # 50PL9126D/37
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Sep 23, 2007 | Flat Panel Televisions
Sony KDF-E60A20 60 in. LCD HDTV Logo
130 people viewed this question
Top Sony Flat Panel Televisions Experts
Brian Sullivan
Brian Sullivan
Paul Bade
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
