Question about Intertherm Heating & Cooling
Air conditioner keeps freezing up - Intertherm Heating & Cooling
    Sergeant:
  • 163 Answers
Unit is low on refrigerant, fix the leak and recharge with correct weight refrigerant found on a label attached to the unit. Best left to a professional.
Posted on Jul 02, 2009
SOURCE: amana window air conditioner 10000 btu
I have an Emerson Quick Cool air conditioner and it keeps freezing up on one side.Would appreciate any help you can give
Posted on Jul 09, 2008
  • 12 Answers
SOURCE: Air keeps freezing up
you may have a ref. leak or possible the fan motor is not running as fast as it is supposed to.
Paolo
Posted on May 06, 2009
  • 400 Answers
SOURCE: my air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
  • 47 Answers
SOURCE: my air conditioner keeps freezing up
Probably 75 to 80 percent of all air conditioner service calls are repaired by simply cleaning the coil fins. If it is a window air conditioner, unplug it from the wall, remove the front cover and brush the coil fins using an up and down motion. Next go outside and brush the outside coil the same way. Then blow through it with water. Too much water pressure can also bend the cooling fins. The inside coil if extremely plugged up can be washed also but it will be necessary to remove it from the window to do so. If this doesn't solve your problem, chances are that it is either low on freon or the compressor is weak. It may be time to look for a new one. I hope this helps
Posted on Jul 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Air Conditioner is freezing up
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
It keeps freezing up if you put it past #5
Hi and welcome to FixYa. I am Kelly. Freeze ups are caused by a couple things.
1. The first thing is a dirty evaporator coil. Air conditioners that run 24 hours a day should be thoroughly cleaned every 90 days.
2. The Blower fan wheel is dirty
3. The fan motor is not running fast enough.
Most of the time these 3 items listed above are the main reasons and Air Conditioner Freezes up.
Thanks for using FixYa,
Kelly
May 10, 2010 | Friedrich Casement SC06H10D Air...
Evaporater freezes up after running for aa short while
HELLO THERE:
When you set the temperature settings down around 64 or lower the unit will freeze up so i recommend to keep it at around 68 or 70 ok this will keep it from freezing also make sure that the unit is free of any obstructions so the air can freely get to the unit ok?
best regards michael
Aug 27, 2009 | Whirlpool ACM184XP Air Conditioner
My air conditioner lines keep freezing up.
Jun 25, 2009 | Heating & Cooling
Paolo
May 05, 2009 | Heating & Cooling
Freezing Up
sounds like air is not flowing properly thru the a/c. if there is a filter you can pull out remove it and clean it.
Robert
Sep 01, 2008 | Fedders A6X05F2D Air Conditioner
Fridgedaire; freezing up
If the coils freezes up half-way-down and lower is due to low freon psi.
Aug 21, 2008 | Frigidaire FAC126P1 wall/window Air...
Goldstar R1804H
well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Jun 28, 2008 | Goldstar R5050 Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Heating & Cooling Logo
89 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
