Question about Acer Aspire 5720-6661 Notebook PC
Internal microphone drivers for Win XP for Aspire 5738. Internal Microphone dows not record the voice when Win XP is installed. However, it works with Win Vista
Skype-microphone is faulty-others cannot hear me
The microphone may not be configured properly in Skype.
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
Mar 12, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
Built in microphone is faulty-cannot be heard-solution
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Mar 09, 2012 | HP Compaq d530 SFF PC Desktop
In my laptop hp compaq cq45 with os windows xp microphone is not working plz solve my problem...
Mar 04, 2012 | Computers & Internet
I have an acer aspire 5738 and windows 7...my problem is that my microphone doesn't work..i can listen to music and staff but i can't record my voice or speak with my friends on msn.This happend...
I assume you made sure that the mic is not on mute. Click on your audio icon and double check. If not I would update the chipset driver. I have attached a link to all the drivers for your Acer. Just select the correct version of Windows 7. Thanks for using FixYa
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1120
May 15, 2011 | Acer Computers & Internet
I can not record anything on my internal microphone on my Acer Aspire One. I am having problems recording things. My computer says I don't have an internal microphone even though I really do. I...
You can reinstall it. Click on Start Menu> All Programs> Acer erecovery management> Restore> Reinstall Application & Drivers> Select the appropriate sound driver (Realtek) and install it. Also visit http://support.acer.com/drivers_download.aspx
and select the appropriate model number and sound driver (realtek)
May 07, 2010 | Acer Computer AOA150 Notebook
I?m facing a problem with built-in microphone that its not working after i install XP.
Try going to the control panel,
  1. click on sound's and audio device's,
  2. in the sound's and audio device's propertie's box click the voice tab at the top,
  3. under voice recording check to see if the internal mic is checked in the voice recording, default device box,
  4. if it is click the volume box, a new box will appear that say's recording control,
  5. make sure the microphone has a check in the box,
  6. under microphone click the advanced tab,
  7. in the advanced tab make sure the microphone boost has a check in the box,
  8. go back to the sound's and audio device's propertie's box under the voice tab,
  9. at the bottom of the box under voice click on test hardware,
  10. on some built in microphone's you have to talk into the area where the mic is located on the laptop.
  11. if it does'nt help try using the device manager to resolve the sound issue's, check to see if the device is enabled, if it is use the troubleshooting tab to see if the device has a conflict, if it's working properly it will say this device is working properly, or try using the update driver tab.
Apr 16, 2009 | HP Compaq Presario CQ50-210US Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Acer Aspire 5720-6661 Notebook PC Logo
334 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
