Question about Panasonic Televison & Video
HI,I HAVE A PANASONIC TX32LED7FA LCD TV.GET NO TURN ON,ONLY RED LED IS FLASHING ONE TIME AT 3 SECONDS.CAN SOMEBODY TELL ME WHAT IS DAMAGED?I NEED A SERVICE MANUAL.THANK YOU.SORRY FOR BAD ENGLISH.PETER.PAGACIK@GMAIL.COM
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
  • 5 Answers
SOURCE: tv lcd akai
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 367 Answers
SOURCE: TRUTECH PLV16190 wont stay on keeps turning off.
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Jun 28, 2009
  • 5 Answers
This is a known fault. John Lewis in the UK sent out an engineer under their 5 yr TV guarantee and completed the firmware upgrade for me. The only other store to compare with them for price and service is Richer Sounds but I believe you now have to buy the warranty for 10% of the purchase price. This problem will persist unless the upgrade is completed. For those of you in the UK, I would insist the seller repairs the problem under the Sale of Goods and Services Act as the TV is not fit for purpose without the upgrade. You have 6 yrs (not a year or 6 months) to claim under this Act.
Posted on Feb 13, 2010
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Kdf-e42a10 i have no power ,only red led 3 time flashing
3 times red light flashing indicates that lamp cover has not been fixed correctly in tv after lamp replacement. Please make sure lamp cover is fixed securely after lamp replacement.
Thanks.
Feb 05, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
Oct 08, 2009 | Sony KDF-E55A20 55 in. LCD Television
Nov 03, 2008 | Televison & Video
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
